Old 05-18-2005, 12:50 PM   #1 (permalink)
Default Front Brake Rotors
Quick question I'm replacing my right front rotor. How hard is it to remove the rotor? Does it just slip off or is it attached with any bolts. All replys appreciated.
totallymann is offline   Reply With Quote
Old 05-18-2005, 01:02 PM   #2 (permalink)
4x4 Adventure Gear
John C's Avatar
You need to remove the caliper, the hub and then bang out the rotor. It's a PIA. The caliper is held on by two 13mm star shaped bolts (use a 12 point socket). The hub is held on with 5 15mm (or 16mm) hex bolts. You will need a c-clip plier and hub nut tool also. Banging out the rotor takes time and a BFH.
John C
1996 DI - 3" AG lift
1990 Kawasaki KL650B Tengai
1989 Kawasaki KLR650
Old 05-18-2005, 01:13 PM   #3 (permalink)
01001010's Avatar
Gallery: 15
What truck is it??? D1, D2? Just to add onto John's post, the hub socket is a 2-1/16th Deep Socket.
JC...
Old 05-18-2005, 01:46 PM   #4 (permalink)
Sorry, It's a '98 D1
Old 05-18-2005, 01:48 PM   #5 (permalink)
01001010's Avatar
Gallery: 15
Then follow John C's instructions, you should be alright, just get a hold of a 2-1/16th deep socket to remove the hub.
JC...
