Old 04-04-2007, 02:18 PM   #1 (permalink)
Default Fuel pressure drops to zero after shutoff, hard to start warm.
I just got this '96 Discovery 5-speed with 166K and I starting to work on the bugs. It's hard to start when warm, as in, I crank a few seconds, stop, crank again, stop, and crank again and usually it starts the third time. I hooked up a fuel pressure gauge and noted the pressure at idle was 30 psi. but when I shut the engine off the pressure dropped to 0 within 10 seconds. Thats the problem. What should I check as the cause? I replaced the filter and I don't think it's leaking injectors.
atikovi is offline   Reply With Quote
Old 04-04-2007, 03:04 PM   #2 (permalink)
There is a valve in the fuel pump that should maintain the pressure, sounds like yours has failed. I believe you have to replace the pump to correct the problem.
Old 04-05-2007, 05:18 AM   #3 (permalink)
Elemental's Avatar
Why do you not think it's injectors?
Old 04-05-2007, 05:43 AM   #4 (permalink)
The fuel pressure bleeds down to zero in 10 seconds. If the injectors were leaking that much I'm sure the engine would be running bad (rich) all the time which it isn't and would smoke a lot when starting up from all the fuel in the cylinders which it's not.
Old 04-05-2007, 06:50 AM   #5 (permalink)
Elemental's Avatar
That makes sense, but its a easy check to confirm. And, Injectors in your vintage do have a high failure rate.
Old 04-05-2007, 07:30 AM   #6 (permalink)
"Former Left Coaster"
wiseguy's Avatar
Question-how does it drive out -and also is there rough ideling as if it s not getting enough fuel?
wiseguy is offline   Reply With Quote
Old 04-05-2007, 08:05 AM   #7 (permalink)
It idles smooth and runs fine otherwise.
Old 04-05-2007, 12:02 PM   #8 (permalink)
wiseguy's Avatar
Atikovi- The reason im asking is because Ihave a 96 disco that does theeee exact 3 cranks and starts right up... drives fine (rough idle). So when Mike said it sounds like a pressure valve .Im not quite sure about that. Ijust put in anew fuel pump hoping that would cure all ,not exactly.So the delima still stands -Id swear threr is some lek of pressur when not in use I just dont know where(and no fuel escaping through pressurevalve near the throttle body . If you or anybody is or have had theses probs please help .ps no chek engine light so i wonder if it would even through a code. see ya. NOT SO WISE guy!
Old 04-05-2007, 12:14 PM   #9 (permalink)
Mean and Green
Are you sure it isn't running rich? Have you pulled the plugs to confirm?
werldcup is offline   Reply With Quote
Old 04-05-2007, 12:57 PM   #10 (permalink)
wiseguy's Avatar
werld - Ichanged out the plugs before I put the pump in... now those plugs varied in decomp . Some where hevily carbed up but I was unsure really how old they where since its relatively new to the family! how do they look if it runs too rich.What would cause that. se ya!
Old 04-05-2007, 01:20 PM   #11 (permalink)
Mean and Green
The plugs will be black and wet if your injectors are dumping excess fuel.
Old 04-05-2007, 01:29 PM   #12 (permalink)
Just installed a new fuel pump. Now after turning the engine off I still have over 25psi fuel pressure 30 minutes later. Problem solved.
Old 04-06-2007, 05:25 AM   #13 (permalink)
wiseguy's Avatar
Im very glad your pump solved you probs !!!! And to world cup-3of the new pluggs had reminants of fuel and turning dark,meaning injects are leaking some fuel that would explain loss of fuel pressure and gas smell DAH. I guess it takes a new perspective to make everything seem so obviuos (even a mechanic friend of mine didnt figure it out .I guess im looking for some injecters ...outstanding .
Old 04-11-2007, 04:44 PM   #14 (permalink)
South_Island_Disco
Another cause of a drop in fuel pressure after shut off, is a split O ring on the fuel pressure regulator.
Unbolt the regulator from the fuel rail and check the condition of the O ring.
Mine was spilt in three places.
Take usual precautions when doing this, battery disconected, fuel rail depressurised and lots of rag under the regulator to catch the fuel that runs out.
South_Island_Disco is offline   Reply With Quote
Old 04-11-2007, 05:07 PM   #15 (permalink)
I spoke too soon when I said the problem was solved. While it does hold pressure now after shut-off and THAT problem is solved, when I took it for a test drive the engine started to miss during acceleration. I still had the fuel pressure gauge connected and saw that the pressure was dropping the more I pressed on the gas. I guess the new fuel pump is too strong for the old and weak pressure regulator to keep the fuel pressure up. I ordered a new regulator and will see what happens after installing it.
