I just got this '96 Discovery 5-speed with 166K and I starting to work on the bugs. It's hard to start when warm, as in, I crank a few seconds, stop, crank again, stop, and crank again and usually it starts the third time. I hooked up a fuel pressure gauge and noted the pressure at idle was 30 psi. but when I shut the engine off the pressure dropped to 0 within 10 seconds. Thats the problem. What should I check as the cause? I replaced the filter and I don't think it's leaking injectors.
The fuel pressure bleeds down to zero in 10 seconds. If the injectors were leaking that much I'm sure the engine would be running bad (rich) all the time which it isn't and would smoke a lot when starting up from all the fuel in the cylinders which it's not.
"Former Left Coaster"
Atikovi- The reason im asking is because Ihave a 96 disco that does theeee exact 3 cranks and starts right up... drives fine (rough idle). So when Mike said it sounds like a pressure valve .Im not quite sure about that. Ijust put in anew fuel pump hoping that would cure all ,not exactly.So the delima still stands -Id swear threr is some lek of pressur when not in use I just dont know where(and no fuel escaping through pressurevalve near the throttle body . If you or anybody is or have had theses probs please help .ps no chek engine light so i wonder if it would even through a code. see ya. NOT SO WISE guy!
#10 (permalink) |
werld - Ichanged out the plugs before I put the pump in... now those plugs varied in decomp . Some where hevily carbed up but I was unsure really how old they where since its relatively new to the family! how do they look if it runs too rich.What would cause that. se ya!
#13 (permalink) |
Im very glad your pump solved you probs !!!! And to world cup-3of the new pluggs had reminants of fuel and turning dark,meaning injects are leaking some fuel that would explain loss of fuel pressure and gas smell DAH. I guess it takes a new perspective to make everything seem so obviuos (even a mechanic friend of mine didnt figure it out .I guess im looking for some injecters ...outstanding .
#14 (permalink) |
South_Island_Disco
Another cause of a drop in fuel pressure after shut off, is a split O ring on the fuel pressure regulator.
Unbolt the regulator from the fuel rail and check the condition of the O ring. Mine was spilt in three places. Take usual precautions when doing this, battery disconected, fuel rail depressurised and lots of rag under the regulator to catch the fuel that runs out. |
#15 (permalink) |
I spoke too soon when I said the problem was solved. While it does hold pressure now after shut-off and THAT problem is solved, when I took it for a test drive the engine started to miss during acceleration. I still had the fuel pressure gauge connected and saw that the pressure was dropping the more I pressed on the gas. I guess the new fuel pump is too strong for the old and weak pressure regulator to keep the fuel pressure up. I ordered a new regulator and will see what happens after installing it.
