My 96 disco 4.0 is having trouble starting when warm. It runs like a champ after it gets started, but it takes a few tries to get it fired up, and once it starts, it idles very high for a short time. A bit more information, and it has only done this twice, but while driving on the highway, it would not accelerate past 2k rpm. I am pretty sure it is either the fuel pump or the fuel pressure regulator, but I am not sure how to tell which it may be.
Thank You all for you help. This is a great forum. : |
Thanks for the advice. I replaced the fuel filter about 9 months ago, so I guess I should do that again first. If I still am not getting 32psi in the rail, any thoughts on how to tell if the problem is the pump or the reg?
thanks again. |
i would put all my money on the pump. the reason it doesnt start cold is because the check valve in the pump is stuck letting the fuel in the rail to leak back to the tank. so when you start it you have to pressurize the rail again. the pump is easily accessable through the floor under the carpet in the cargo area. the problem at 2k rpm is also because of the pumps weak pressure. good luck. and if you do the pump make sure to get a new gaket ring and accorn fittings if applicable.
#9 (permalink) |
My experience is that the pumps on Land Rovers don’t last much past 80 to 100 thousand miles, and it’s usually the brushes in the motor that go first. Dent is right, a louder than usual whering noise is a good sign that the pump is on its last legs. Or no noise at all when you turn the ignition on.
Don’t waste time with the fuel filter if you changed it 9 months ago, I cant see that it would be clogged up in that short amount of time. If you think you are having fuel pressure/delivery problems and you have 80K on an original I WOULD consider changing it. Like I said if it where ME I would get it changed. If it goes out 50 miles from home you’ll be towing it back and when they go they just stop with out warning. I know. ![]() |
#11 (permalink) |
no luck with the job hunt but thanks 4 asking. good luck putting the pump in if you need guidance please dont hesitate to ask. also if i were you i would access the pump cover and put some rust penetrant on the screws they tend to seize and break. also an impact driver will help get them off in one piece
#12 (permalink) |
Saw this on a site, very detailed on how to do the job...pics and all.
http://www.4x4wire.com/rover/mainten...elpumpinstall/ Its for a '96 Disco. B. |
#13 (permalink) |
If the fuel pressure is found to be acceptable, or the problem persists with replacing of the fuel pump, it may well be leaking injectors. You may find the hard start is due to flooding of the cylinders-the high engine speed leads me to believe this may be the problem.
These problems seem to come in spurts, I have now replaced three fuel pumps in the last month! Peace, PT |
#14 (permalink) |
You know, originally I thought the problem may be leaky injectors as well, but I don't think that would explain the problem when driving down the highway, would it? The truck seems to start and run fine while it it cold, which makes me think it may also be the fuel temp sensor. I will start with the pump I guess, and see what happens after I get that put in. It could be a combination of things, I suppose.
Thanks |
