Old 05-17-2006, 06:10 PM   #1 (permalink)
Default Fuel Pressure Regulator bad?
In trying to track down a problem, I've tested my fuel pressure regulator. With just the ignition on (without the vehicle started), my fuel pressure at the rail is 38 psi. I let it sit for five minutes and it didn't fall. After starting the engine, the fuel pressure rises to 48 psi and stays there at normal idle. If I rev the engine, it stays at 48 psi. If I pull the vacuum hose off of the fuel pressure regulator, no change...48 psi. Is my regulator bad? Thanks for any replies.
Wade
wade is offline   Reply With Quote
Old 05-18-2006, 07:52 AM   #2 (permalink)
Wade,
I don't think you have a problem. You would have a problem if the pressure dropped after sitting, that would indicate a bad back flow valve in the fuel pump assembly.
Otherwise I think you are fine.
