Old 12-05-2005, 07:57 PM   #1 (permalink)
Default Fuel pump/ Fuel tank issue.
Okay. So there I am on saturday, was going to go offroading, I refill my power steering fluid, fixed my previous problem I was all set to go. I pull into the gas station, fill up to full, get in the car. Start the engine, and its barely running 100-0RPM the engine shakes rambles and then stalls. I tried starting the car under full throttle and nothing, would shake and stall everytime. So I start checking the usual. Check the MAF ( completely disconect it, that does nothing. ), I checked the ignition coil/ distributor cap/ wires ( usually the reason why it doesnt start ) and everything was fine. Nothing leaking, nothing wrong, just wont stay on. Eventually it doesnt even turn on and studder, just tries to turn on with no avail. So I figure it is not getting any fuel. I call AAA to get me towed, in the 2 hours I had till the latest time they come, my mechanic comes. And he determines the same thing, no fuel. My father comes in the ML, we get a metal wrench out of the ML, the mechanic takes it, and while I crank, he hits the fuel tanks really hard and it turns over immediately..
So my question is uhh, wtf? Was there something in the fuel?
This keeps on happening now everyday, I left it at the mechanic and they're saying new fuel pump, but my fuel pump is only a little over a year old and my gas tank is less than 6 months old ( recall ) Any ideas as what this might be?
-Militant Grunt
Militant-Grunt is offline   Reply With Quote
Old 12-05-2005, 08:45 PM   #2 (permalink)
DISCO INCUBUS's Avatar
When you turn the ignition to the run pos do you hear the fuel pump making a steady
whining sound or is there a grumbling? You might of had a new pump put in prior to the
tank recall but who is to say the douchebags didn't swap out your pump with a used one? Just because someone is wearing an official LAND ROVER uniform it doesn't make
them honest.
Not painting with a broad brush but i have been looked square in the face and lied to
by L/R service managers and tech's a few times.
I hope you don't go to the asswipes in manhattan on 57th st oofahh
DISCO INCUBUS is offline   Reply With Quote
Old 12-05-2005, 09:01 PM   #3 (permalink)
them honest.
That is where I got the recall done.. I only go to a private mechanic now, but for recall thats where i went 54th and 11th..
-Militant Grunt
Old 12-06-2005, 07:23 PM   #4 (permalink)
Have you gone into the tank yet, looking for a bad connection or ground problem??
By the way, when you changed out the fuel tank, did you replace the fuel filter?? Probably not a factor for your current problem but should be done, they plug up easily.
Mike J.
Old 12-06-2005, 10:05 PM   #5 (permalink)
Otherwise known as STEVE
Just because stuff is new doesn't mean it's good. That dealer sucks bigtime and I wouldn't hesitate to second guess their ability to do ANYTHING properly.
2002 Freelander
2000 DII w/CDL
1967 SIIA 109SW
Former Rovers
2004 Modded "S" Disco, R.I.P.
2004 G4 Disco
2002 Modded Freelander
1995 Modded Disco
1994 D-90 #8
1993 NAS D110
1990 Range Rover County
1973 SIII 88
1972 Range Rover 2 door
Old 12-07-2005, 04:50 PM   #6 (permalink)
Im with Muddy oval on this one. Manhatten doesnt have a decent rep even among dealers.
We got stuck from those bastards not doing recalls at all but claiming them on the Range ROvers. the customers would drive to Vermont to go skiing and the front diffs would break and they would get towed to us. The computer would show a recall done but we pulled it apart and found nothing done. No drilling or new grease.
We did so many we were pissed. Its getting to be ski season again and I bet we will soon see some more from them.
Old 12-07-2005, 08:25 PM   #7 (permalink)
Well the diagnosis from my mechanic is this, the fuel pump is failing, is starts sometimes, and other times is does not. Its making a lot of noise, you can really hear it when standing under the tank. It makes a high pitched whirring noise ( is this norm?) So for now I ordered a fuel pump from a junk yard. Got it for about 170. Should be like 250 tops with labor. Sigh.. my mom really cant afford this, she might sell the car soon.
-Militant Grunt
Old 12-07-2005, 09:16 PM   #8 (permalink)
PPR
Silver Streak's Avatar
$170 for a used one?
Silver Streak is offline   Reply With Quote
Old 12-07-2005, 09:47 PM   #9 (permalink)
yep.. Is that a bad price?
-Militant Grunt
Old 12-07-2005, 09:54 PM   #10 (permalink)
PPR
You can get a new OEM aftermarket for $250. I wouldn't expect much out of the used one myself. $50 for a used pump is more like it.
