Old 10-20-2007, 06:13 PM   #1 (permalink)
Default Fuel Pump Relay Bypass??
I have my 94' Disco 3.9 tore apart STILL!! I need to know if there is way to by pass the fuel pump relay to get a fuel sample at the return line to check for any problems with water or something else. My injectors are "pissing" instead of spraying. We have replaced the fuel pump thus far. I have the rail and injectors off ready to send to Linder but a buddy of mine suggested this. LMK what you'all think.
Rob...
netphd is offline   Reply With Quote
Old 10-21-2007, 07:13 AM   #2 (permalink)
jump it at the source.
or at the fuel pump shutoff.
two things its not a bad idea to replace the fuel lines and the fuel rail cause once the rust happens in the injectors its a fair bet its thruout the lines.
honestly I would replace the lines cause they are brittle anyway.
did you clean the fuel tank of debris as well.
