Links
Old 03-25-2006, 04:02 PM   #1 (permalink)
Unhappy fuel rail wont pressurize
Hey guys, I just replaced my valve cover gaskets on my 96 disco, and now the damn thing wont start. Im not getting any pressure to the fuel rail. Was wondering if anyone has had the same problem or if anyone knows what the problem could be.
Thanks,
Kyle
etrnly is offline   Reply With Quote
Old 03-25-2006, 04:45 PM   #2 (permalink)
Did you tap the fuel cutoff switch by accident. Or did you blow a fuse.
Old 03-25-2006, 04:55 PM   #3 (permalink)
I checked the fuses they are all good, where is the fuel cutoff switch located?
Old 03-25-2006, 05:08 PM   #4 (permalink)
passenger side on the firewall. Its a big black rubber button with two wires on it.
Old 03-25-2006, 05:34 PM   #5 (permalink)
You are a life saver man! I guess when you depressurize the fuel lines it will kick that shut off valve on. Thanks a million!!!!
Old 03-25-2006, 05:46 PM   #6 (permalink)
Depressurizing the fuel system doesnt trip it.
You probably bumped it. thats what triggers it.
