Old 11-15-2006, 04:16 PM   #1 (permalink)
Default Gaiter Kits ?
Looking for comments on Gaiter Kits for Swivel Housings. Are they worth it or not?
"DO YOUR DUTY IN ALL THINGS. YOU CANNOT DO MORE. YOU SHOULD NEVER WISH TO DO LESS." GENERAL ROBERT E. LEE
Rebelman is offline   Reply With Quote
Old 11-15-2006, 07:50 PM   #2 (permalink)
Super Moderator
Disco's Avatar
I don't know much about them. I guess anything that helps protect 'your balls' from dirt, mud etc, is not a bad idea.
Old 11-16-2006, 06:13 PM   #3 (permalink)
Otherwise known as STEVE
traps moisture, sand etc. Will corrode your balls.
2002 Freelander
2000 DII w/CDL
1967 SIIA 109SW
Former Rovers
2004 Modded "S" Disco, R.I.P.
2004 G4 Disco
2002 Modded Freelander
1995 Modded Disco
1994 D-90 #8
1993 NAS D110
1990 Range Rover County
1973 SIII 88
1972 Range Rover 2 door
Old 11-16-2006, 07:39 PM   #4 (permalink)
Ian Matthews
p76rangie's Avatar
Let them fly free in the breeze. Muddy Oval's comments X 2.
Old 11-17-2006, 03:55 AM   #5 (permalink)
Here's a review that I saw the other day....
http://www.difflock.com/buyersguide/...t_Gaiter.shtml
Kevin
88 RRC "Audrey"
Old 11-17-2006, 10:36 AM   #6 (permalink)
not so much a review as a sales ad. When the military uses them, it actually changes the maintenance schedule intervals- they have to service them more often because it traps grit, moisture etc. Even condensation can be a problem with no ventilation.
2002 Freelander
2000 DII w/CDL
1967 SIIA 109SW
Former Rovers
2004 G4 Disco
1995 Modded Disco
1994 D-90 #8
1993 NAS D110
1973 SIII 88
Old 11-17-2006, 06:22 PM   #7 (permalink)
fivespddisco's Avatar
Gallery: 10
If you take them off road there is a good chance they rip on rocks or sticks. and x2 on the water traped on the inside. maybe not a bad idea for winter Street driving to avoid the salt.
fivespddisco is offline   Reply With Quote
Old 11-18-2006, 06:07 AM   #8 (permalink)
Thanks everyone. I think I will hold off on the gaiters awhile. I am currently using the regular oil in the housings. Can't make up my mind whether the new grease is better or not? Also, does anyone know the answer to this one? Do you have to have an alignment done if you put a new bumper and winch on the vehicle because of the added weight? Thanks Again
Old 11-18-2006, 08:28 PM   #9 (permalink)
Super Moderator
Disco's Avatar
I wouldn't think so, however this will depend on how much extra weight you have added. If the front end of your vehicle is sagging after the install you will need to fit heavy duty springs, and then, just as a general maintenance procedure, have a wheel alignment done.
Old 11-19-2006, 09:24 AM   #10 (permalink)
Thanks. I guess the new bumper system and winch weighs about 300#. I already put 2" Big Blue springs on and it did not sag much at all after installing the new bumper. Maybe I can get by without new alignment.
