Old 02-14-2005, 01:03 PM   #1 (permalink)
Question Gear oil smell
Hey,
maybe u can all help me.. I have a strong smell of gear oil when I exit vehicle after its running.. front/rear diff are not leaking and oil is good. No wheel seals semm to be leaking?/ where is the oil coming from?/ If u can help me out that would be awesome.
thanks Eric
undefinedundefined
GentrysRover is offline   Reply With Quote
Old 02-14-2005, 03:58 PM   #2 (permalink)
If you are smelling oil, the first place to look would be the v/c gaskets, if one is leaking they will drip onto the exhaust manifold.
Mike J.
Old 02-14-2005, 04:07 PM   #3 (permalink)
LRDMICHELE's Avatar
I have the same problem sometimes. I think mine is due to a slow leak w/the power steering fluid, and my thought is that when the leak develops a drop the fluid drips and it gets hot and smells. Since it's only a slow leak, it doesn't always drip when the car is hot, so the smell is intermittent. That's my theory anyway, and I hope that's what it is! Whew, does that make sense? Good luck, Michele
LRDMICHELE is offline   Reply With Quote
Old 02-15-2005, 12:59 AM   #4 (permalink)
Hi Eric
Do you get spots of oil/dust on your back door/window? Maybe the rear seal from the transfer case as it also has gear oil (the gearbox has that red stuff that smells like cordial or something).
Cheers
Ben
Ben
Chick Magnet is offline   Reply With Quote
Old 02-15-2005, 07:03 AM   #5 (permalink)
4x4 Adventure Gear
John C's Avatar
It's probably gear oil leaking thru your hub seals. The heat of the rotors makes it more noticeable. Just check the back of the tires for any oil stains.
John C
1996 DI - 3" AG lift
1990 Kawasaki KL650B Tengai
1989 Kawasaki KLR650
