Old 09-04-2008, 10:01 PM   #1 (permalink)
Default gearbox/transfer case "clunk"
hey guys,
i have had 3, series 1 discos and all three have a very audible "clunk" when shifting. is this a big deal? the only thing that stops me from taking it down to the garage is that all of the discos ive had make the same noise.
ideas?
cheers guys!
alibabu22 is offline   Reply With Quote
Old 09-05-2008, 01:39 AM   #2 (permalink)
Dutchgit's Avatar
Taking up drive ? Selecting reverse ? Shifting gear ? Auto or Man. ?
Every Rover I ever had (not the latest models I have to add) have clunked in one way or another. It has never bothered me because none of them ever broke anything on the transmission.
The higher the mileage, the more play there will be on every gear.
Nothing is sure but death and taxes.
Dutchgit is offline   Reply With Quote
Old 09-05-2008, 02:46 PM   #3 (permalink)
its an auto box, going from park to drive and reverse, then again back down
Old 09-06-2008, 01:49 AM   #4 (permalink)
Dutchgit's Avatar
It's probably the splines on the shaft that connect the gearbox to the transferbox.
Start saving to have it fixed or drive it untill it gives and fit a gearbox combo you've found somewhere in the mean time.
Old 09-16-2008, 03:16 PM   #5 (permalink)
its started clunking under acceleration and deceleration now, ugh this sounds expensive!
Old 09-21-2008, 08:53 AM   #6 (permalink)
1999 Disco II 'The Rhino' 170,000 miles and going
SafariDave's Avatar
What year is it?
The City is a Jungle.
1999 LR Disco II SD The Rhino
1991 RRC (Sold) We will miss the Turtle
1988 RRC (sold)
SafariDave is offline   Reply With Quote
Old 09-21-2008, 06:43 PM   #7 (permalink)
99'
Old 09-22-2008, 06:55 PM   #8 (permalink)
You can replace the stub shaft on the trans and get a new style input gear that is drilled for oiling
roverhouse is offline   Reply With Quote
Old 09-22-2008, 11:16 PM   #9 (permalink)
Default Lt230 transfer box
Originally Posted by alibabu22 View Post
hey guys,
ideas?
cheers guys!
Check your transferbox number, if its starts with 36D it is not likely to be the input spline wear, however if it starts with 28D then more likely it could well be spline wear. The up grade gear is part No FTC5087 & the coupling is FTC 5090. They are easy to get at from PTO cover if you want to check them.
regards Ray
silverhead is offline   Reply With Quote
Old 09-25-2008, 10:19 PM   #10 (permalink)
cheers budd!
Alistair
Old 10-01-2008, 10:05 PM   #11 (permalink)
Bwana's Avatar
Start with the easy stuff first. Check your engine and transmission mounts.
Bwana is offline   Reply With Quote
A rookie attempts to change transfer case chain skipbrakes Range Rover P38, Mk III and Range Rover Sport 1 09-02-2008 09:18 PM
Changing out a transfer case on a 1995 Disco D1 texaninmass Discovery Series I 0 04-14-2008 07:12 AM
Diff Lock/Follow-up to transfer case removal helievacpilot Discovery Series II 2 03-28-2007 09:55 AM
Renewing fluids in differential, transfer case, swivel housings glenncof Range Rover Classic 2 03-05-2007 12:37 PM
Transfer case noise. BIRD Discovery Series II 5 01-25-2005 08:46 AM
