Old 10-04-2005, 11:16 AM   #1 (permalink)
Exclamation Green Trailer Light On Dash?
HERES ONE FOR YOU GUYS THEN.
WHEN I INDICATE TO TURN RIGHT A GREEN TRAILER FLASHES ONCE THIS IS NORMAL BUT WHEN I INDICATE LEFT IT KEEPS FLASHING IN CONJUCTION WITH THE INDICATOR,
I HAVE CHECK THE INDICATORS AND THEY SEEM TO BE WORKING FINE,
COULD ANYONE GIVE ME THERE THOUGHTS ON THIS.
MANY THANKS FOR ANY REPLYS
zerocool is offline   Reply With Quote
Old 10-04-2005, 11:37 AM   #2 (permalink)
Rocky Mountain High
Funrover's Avatar
do you have trailer wireing on your rover?
Old 10-04-2005, 02:41 PM   #3 (permalink)
Professional Yorkshireman
Bush Tucker Man's Avatar
I guess that's 'MOGWAI' off 'Mud-Club'.
See the replies there
Richard A Thackeray
Yorkshire Born & Bred. And Proud Of It
Defender 110Td5 'Heritage'; S50 RAT
Jaguar XKR; X88 JLT
"Stop The Press!!, Website Updated On; 8th August 2008"
"You Can Allus Tell A Yorkshireman, But You Can't tell Him Owt!"
Bush Tucker Man is offline   Reply With Quote
Old 10-04-2005, 02:57 PM   #4 (permalink)
texasrover's Avatar
Check your bulbs. You may have a bulb burnt out. Simple approach for starters.
That is not a leak! That is undercarriage rust inhibitor.
98 Discovery
Old 10-05-2005, 06:58 AM   #5 (permalink)
If the bulb is not burnt out, clean the bulb socket on the left side. If this dosen't work try swaping the bulbs.
Roverdisco98 is offline   Reply With Quote
Old 10-05-2005, 03:47 PM   #6 (permalink)
Check the trailer socket itself - most likely it's full of damp mud or something and is causing just enough current to pass to make it think there's a trailer attached. Had the same on mine
A good squirt of WD40 or some other protective stuff is normally enough to restore things back to normal
The trailer light is SUPPOSED to flash when there's a trailer attached to let you know the bulbs are working
nosnibod is offline   Reply With Quote
