Hey everyone...I drove to dinner the other night, new starter, fresh battery a few weeks ago. When we came out, would not start. Lights worked, turned key, nothing. Fiddled around, noticed the BRAKE light was on, looked at the hand brake, did not set it beacuse was on a flat spot, but the handle was up slightly. Tried to release, but just kept springing back up. Found if I held it down, the truck would start. So, it started, and made it home, barely. It started to feel like the parking brake was engaged, took lots of foot feed to overcome and move. Any ideas???
Elephantitis penisitis
Crawl underneath and adjust it. And check your fluid in the reservoir.
#4 (permalink) | |
Just re-read your initial post... sounds like Lucas is doing his thing... Not sure why that would cause your truck not to start. Sometimes my 96 doesn't start when I turn the key but starts if I try it again. How many times did you try to start it before you depressed the hand brake?
#6 (permalink) | |
The Best 4X4XFar
Also if the hand brake is sticking don't drive it, LR hand brakes work on the gearbox not on the wheels so forcing it to move with the hand brake on is damaging to the transmission.
Land Rover Discovery (3 Door) 200Tdi 5-speed ![]() Mods:Allisport LARGE FMIC | Allisport Tuned | Simex Jungle Trekker II 33.11.50R15 Tyres | 15x8 8 Spokes | Heavy Duty Uprated Suspension (shocks & springs) | Wheel arch Flares | 1" Wheel Spacers | Custom Straight Thru Exhaust | Custom Trimmed Front bumper with twin NATO Hooks | Custom Rear Bumper with single Large NATO Hook 360˚ Swival | Front Light Guards | Custom Aluminium Rear Floor | Bonnet Straps | 100w Spot Lights | Upgraded Headlights The Best 4X4XFar |
#7 (permalink) | |
MG
![]() Join Date: Aug 2005
At the base of the brake handle (you have to pull the dustcover off to see it), there's a sensor (a switch, really) that turns off the e-brake warning light. Could this cause a problem if it's shorted out?
________________________ MG '95 Disco I, 3.9L V8i 5-speed Discoverying Bolivia... |
