Old 10-20-2005, 04:50 PM   #1 (permalink)
Default Hard starting '94 D1 ?????
I have a '94 D1 i purchased about a month ago.. When I bought it it had a miss, so I changed the plugs, wires, rotor button and distributor cap. That took care of the miss, but when cold it is difficult to start. I have to crank the starter for at least 10-15 seconds before it will begin to hit, sometimes I think it helps to give it a little gas while cranking.. I am debating changing the coil and possible the elec. module, but am not certain I am heading in the right direction.. I still have to check the timing also. When the engine is warm, if I shut it off for 5 minutes or less, it will start right up within a few seconds, but if it has set overnight or even 30 minutes or so, it takes a lot of craking to get it to fire... Before i start changing out more parts I thought I would ask for some opinions???
Thanks for your help.
Martin
Unruely is offline   Reply With Quote
Old 10-20-2005, 05:14 PM   #2 (permalink)
Martin
Martin, I dont know how you would go about it, but you should check fuel pressure after sitting overnight, it seems that fuel is draining away over night. Or you have a faulty fuel pump, have it checked, Regards Frank.
FrankS is offline   Reply With Quote
Old 10-20-2005, 10:40 PM   #3 (permalink)
Elephantitis penisitis
A fuel pump is one of those parts you should always carry an extra one of. Like a brake indicator so when yours goes out in the middle of nowhere, that 30 dollar part can get you home. Not that I'm talking from experience or anything
Old 10-21-2005, 03:37 AM   #4 (permalink)
I am leaning more toward the injectors at this time.. After letting it sit all night, I pushed and held the gas pedal to the floor and it started instantly. i believe that the injectors are leaking off and flooding the cylinders???
Martin
