Old 08-01-2007, 01:54 PM   #1 (permalink)
Default Head Light Switch
My parking lights, dash lights, and tail lights are not working,but my head lights are fine. Turn signals work, hazzard light fine, and brake lights work and I am running my rear fog lights to act as my tail lights. I have checked fuses they look fine. I have heard of a head light switch causing the problem. Anyone have any idea where it is located and how to remove the thing? Or any other suggestions?
jdool76 is offline   Reply With Quote
Old 01-16-2008, 02:58 PM   #2 (permalink)
cskone's Avatar
I second this...what's up w/ the parking lights not working on nearly every LR i see @ night??
Skoner
cskone is offline   Reply With Quote
Old 01-16-2008, 04:20 PM   #3 (permalink)
Thor's Avatar
They don't have speed... so they use stealth.
Todd
Carpe Rangius Roverum
Old 01-16-2008, 05:10 PM   #4 (permalink)
2004 Discovery II driver
exactly, the government actually based the F117 off of a Defender 110 with a spoiler.
stolenheron is offline   Reply With Quote
Old 01-17-2008, 01:54 PM   #5 (permalink)
cskone's Avatar
Seriously though...what is behind the parking lights being out? I would like to fix it if i could w/o rewiring my whole car.
Skoner
Old 01-17-2008, 04:38 PM   #6 (permalink)
mudmonkey's Avatar
My Disco2 has just picked up a 10 second delay between turning on the headlights and the dashboard and trailer when connected lights coming on Any ideas???
D2 with stuff added
mudmonkey is offline   Reply With Quote
Old 01-17-2008, 08:52 PM   #7 (permalink)
Headlight switch. When I had identical issues, I removed the switch (take off the covers around the steering) undo a screw and the swtich slides out. It might be a little stiff and needs to slide straight on the rails to come out so take it easy. I sprayed a bunch contact cleaner inside down where the stalk enters the unit, to give the contacts a good cleaning. You can probably take it apart, but spraying the cleaner and working the switch did it for me. Been fine for 2 months now, for how long, I don't know, but a new one is something like $150..
1994 Discovery
vray is offline   Reply With Quote
Old 01-26-2008, 08:39 AM   #8 (permalink)
I had the same issues on my 95 disco. You need to turn the stearing wheel to get to the two screws on the headlight switch. I cleaned the switch and has worked great for over a year now. The whole fix took just over an hour.
Greater minds than mine
1995 disco
russdonna is offline   Reply With Quote
