Old 11-24-2004, 10:39 AM   #1 (permalink)
Default Headliner
I have a 95 Disc and for about a year now the headliner has been progressively falling down. It was ok at first but now its just annoying. Any sugguestions for how to go about getting it repaired and has anyone had it done before? I suspect its going to be pretty expensive considering that I have the two sunroofs that would also need to be cut around for a new headliner. Thanks for your help.
Kristin is offline   Reply With Quote
Old 11-25-2004, 06:34 AM   #2 (permalink)
You might want to check and see if there is an auto seat repair shop in your area that works on vinyl tops, convertible tops and interiors. They should be able to give you some options, if you are lucky, you may be able to resecure your old head liner.
Good luck,
Mike J.
