Old 02-06-2005, 03:25 PM   #1 (permalink)
Question headliner removal
hey ya'll
I wanna remove my head liner or one side anyways to put a antenna through the roof.. I wanna drill a 1/16 hole next to where roof rack mounts through roof any suggestions on removing a side so I can get to it .. 95 disco
Thanks Eric
undefinedundefined
GentrysRover is offline   Reply With Quote
Old 02-06-2005, 04:35 PM   #2 (permalink)
Super Moderator
Disco's Avatar
A more logical approach would be to use a gutter mount.
Old 02-06-2005, 05:41 PM   #3 (permalink)
Gutter mount antennas don't begin to have the power and reception of one drilled dead center in that big metal top. That is where a radio shop did mine and I have perfect 360 degree reception and transmitting.
I am not sure what they did when they pulled the head linner down, but it was down and back up to 15 minutes.
What type of antenna are you going to use? The Wison 1000 works well with a 4' stainless.
Mike J.
Old 02-06-2005, 09:57 PM   #4 (permalink)
Super Moderator
Disco's Avatar
Great for desert work but on bush tracks, unless it has a spring type base, you'd be replacing it quite often.
Old 02-06-2005, 10:04 PM   #5 (permalink)
Super Moderator
Disco's Avatar
BTW Mike, is that your antenna, on your truck, in the photo attachment you sent Chicago Dan. With one that big you must be able to communicate for thousand of miles. Hehe!
Old 02-07-2005, 05:17 PM   #6 (permalink)
Banned
Default do it yourself
use a heavy vacumn line or heater hose over a drill bit to allow only enough exposed
drill bit to penetrate roof and fish the coax to approprite location. with out
ripping the headliner! if you do use red green approved duct tape!
use only the highest quality british duct tape,
green00disc is offline   Reply With Quote
