Old 06-30-2005, 04:18 PM   #1 (permalink)
JesusIsLord
9dawgs's Avatar
Gallery: 2
Default Headliner sag...
Has anyone else had problems with their headliners? I just picked up a '99 Discovery and noticed today that the headliner is sagging in sections. Is there a kit to replace it or should I just resolve myself to visit the local headliner shop...
9dawgs
'99 Discovery I
'99 Chevy Astro 4X2 w/4" Lift (family truckster)
17' Basstracker w/40HP Mercury
11' Jon Boat w/numerous antique outboards
9dawgs is offline   Reply With Quote
Old 06-30-2005, 04:40 PM   #2 (permalink)
hey 9dawgs i hear that in warm climates that this is a common problem. i have looked at a few disco's before purchasing my 97 se7,and a few had this same problems with the headliner.
overhead1440 is offline   Reply With Quote
Old 06-30-2005, 04:41 PM   #3 (permalink)
what i have done on other vehicles is take the headliner out, get some new material (if needed) and some spray on adhesive (at the fabric store) and re apply the liner.
rov'n is offline   Reply With Quote
Old 07-05-2005, 08:54 PM   #4 (permalink)
For what it's worth, I had a little headliner sag by the driver's side front (edge hanging down, very not cool). I tried some old arts-and-crafts spray-on adhesive (maybe it was 'photo mount'?) and couldn't be happier with the result.
Might wanna do it before retiring for the evening, so the scent disperses. And then plan on windows open for the first drive.
Also, some of the foam seems to come down with the headliner, so if you're talking about replacing vast reams of headliner, might wanna test or check to see what's going on with the foam underneath. (Mine was just a small area so glued back with no problem.)
BlackAndTan is offline   Reply With Quote
Old 07-06-2005, 06:15 AM   #5 (permalink)
texasrover's Avatar
I will have to give that a try. On the passenger side I noticed the same problem. I have no idea how long it has been sagging but noticed when I opened the sun roof... I really should look around the car more!
I have a 98 Land Rover disco... Texas is warm!
Old 07-07-2005, 09:59 AM   #6 (permalink)
JesusIsLord
9dawgs's Avatar
Gallery: 2
Originally Posted by BlackAndTan
For what it's worth, I had a little headliner sag by the driver's side front (edge hanging down, very not cool). I tried some old arts-and-crafts spray-on adhesive (maybe it was 'photo mount'?) and couldn't be happier with the result..
How did you get to the sag part? Did you have to remove the headliner to get behind the fabric?
9dawgs
'99 Discovery I
Old 07-07-2005, 10:37 AM   #7 (permalink)
4x4 Adventure Gear
John C's Avatar
The heat and wind will cause the headliner to sag.
Your best bet is to remove the headliner, remove the fabric carefully, clean off the sticky stuff and re-spray it using 3M adhesive (like rov'n mentioned).
Removing the headliner takes less than 30 mins.
Good luck
John C
1996 DI - 3" AG lift
1990 Kawasaki KL650B Tengai
1989 Kawasaki KLR650
Old 07-07-2005, 12:11 PM   #8 (permalink)
JesusIsLord
9dawgs's Avatar
Gallery: 2
Good luck
Cool, thanks for the info. I'll check into it this weekend if the Hurricane doesn't steer our way.
I'll let you know how it works out. BTW, what did you use to clean off the sticky stuff?
9dawgs
'99 Discovery I
