Do you have a sunroof? If so, the Sunroof drain pipes are clogged.
JC... 1996 Discovery SE - The Blue Marlin - gone =( 1965 Series IIa 109 RHD Dsl - Wilks www.TerraTrekker.com
Has it been raining in your area, is your sunn roof all the way closed?? Most likely it is a drain tube from the front sun roof, sounds like a good time to go see your mechanic. Make sure to clean and dry the head liner so it doens't get stained or drrop.
Mike |
Most likely it is the sunroof drain pipe like everybody has been suggesting but as an alternative. I had a leaky roof rail because someone had installed it improperly and whenever the truck was parked off camber in the rain water would leak in under the foam seal and drip down onto the headliner.
'97 Disco
