Old 10-30-2007, 02:27 PM   #1 (permalink)
Default help!
the roof is leaking, and coming in right above the passenger sun shade. thats about all i kno.
floridadiscoI is offline   Reply With Quote
Old 10-30-2007, 02:43 PM   #2 (permalink)
01001010's Avatar
Gallery: 15
Do you have a sunroof? If so, the Sunroof drain pipes are clogged.
JC...
1965 Series IIa 109 RHD Dsl - Wilks
www.TerraTrekker.com
Old 10-30-2007, 02:43 PM   #3 (permalink)
Has it been raining in your area, is your sunn roof all the way closed?? Most likely it is a drain tube from the front sun roof, sounds like a good time to go see your mechanic. Make sure to clean and dry the head liner so it doens't get stained or drrop.
Old 10-31-2007, 05:44 AM   #4 (permalink)
Buddy Lee's Avatar
Most likely it is the sunroof drain pipe like everybody has been suggesting but as an alternative. I had a leaky roof rail because someone had installed it improperly and whenever the truck was parked off camber in the rain water would leak in under the foam seal and drip down onto the headliner.
'97 Disco
Buddy Lee is offline   Reply With Quote
Old 10-31-2007, 07:40 PM   #5 (permalink)
i do have sun roofs, and i live in florida, so it always rains.
nd i got got it back from the stealership.
