Old 11-03-2005, 11:20 AM   #1 (permalink)
Default Help!!!
i installed a new radio and i can hear my ignition through the speakers!!!
rov'n is offline   Reply With Quote
Old 11-03-2005, 11:53 AM   #2 (permalink)
Green DISCO UNO
Default hihihihih.............
sorry but I can't stop laughing
Eduardo is offline   Reply With Quote
Old 11-03-2005, 12:17 PM   #3 (permalink)
Green DISCO UNO
Default I'm back
I'm sorry I was laughing because it happen to me to if you install a radio you need a Land Rover code. The dealer want it $ 500.00 for the Radio and instillation, good luck
Old 11-03-2005, 12:26 PM   #4 (permalink)
its an after market radio, i got it figured out, needed a filter for the new system
Old 11-25-2005, 01:15 PM   #5 (permalink)
hurray for books!
DiscoTex's Avatar
were does the filter go?
DiscoTex is offline   Reply With Quote
Old 11-26-2005, 08:32 AM   #6 (permalink)
Banned
It's just a bad ground...You can install one of those filters, but it will reallt rob you of power in the radio. Thus, you can't crank it up very loud, or not nearly as loud as it could be.
Hank is offline   Reply With Quote
Old 11-26-2005, 10:35 AM   #7 (permalink)
definitely bad ground
MuddyDisco23 is offline   Reply With Quote
Old 11-26-2005, 02:35 PM   #8 (permalink)
well not to rain on your parade...but i checked the ground and even relocated didnt help, installed 2 filters one for the front amplification system and one for the rear amplification system and no more noise!
stereo rocks the house!
Old 11-26-2005, 03:00 PM   #9 (permalink)
Forward!
Badger1's Avatar
Gallery: 1
Old 11-26-2005, 03:22 PM   #10 (permalink)
The Urban Motorist
Adam in NYC USA's Avatar
Lightbulb You should do a few more things....
Check your electrical connections,
make sure your battery is up to snuff with the new electrical toys,
is your stock alternator up to the task? You will need to charge your battery and play your amps at the same time when you are driving.
and try to snuff that noise at the source rather than at the amplifiers. You do have EMI supression wires on your ignition system right? (Yeh, right, grin).
BTW, flexible tin-covered copper straps to the hood and chassis grounds do a lot to suppress radiated Electromagnetic Interference.
Adam in NYC.
Old 11-26-2005, 03:45 PM   #11 (permalink)
Adam in NYC.
all of the connections are made via wiring harness, didnt have to splice into anything. load on the alternator is just fine, running a capacitor to the sub amplifier in back.
Old 11-26-2005, 04:54 PM   #12 (permalink)
The Urban Motorist
Lightbulb Okay.....
What was the voltage drop across the battery when you engage the wiring harness? BTW, when that capacitor discharges, it has to get that electrical energy from somewhere, like the battery and the alternator.
You might want to see if your new gadgets are not causing excessive voltage drop, which can cause additional ignition noise on the power rail. Not to mention that you will drawing additional power from charging system, causing them to work harder and heat up more.
Measure your voltage.
Start the car.
Let the idle do its thing and kick down.
Play something loud and continous without using any of the headlighting.
Turn on all your gadgets including your lighting.
Nothing looks dim or sounds distorted? Then you did a good job. If it does the same in the dead of winter, you did a great job.
Adam in NYC
Old 11-27-2005, 04:02 AM   #13 (permalink)
Banned
Again.....It's a bad ground in your system somewhere. Does not have to be at the radio - it could be anywhere. Amp, battery, engine, etc...
Are you sure your constant 12v is not the 12v lead to your ignition, or something stupid like that?
Old 11-28-2005, 12:08 PM   #14 (permalink)
Start the car.
Adam in NYC
everything checks out ok, the stereo made noise just as soon as i hooked up the new deck without any load at all, the stock radio did not make that noise. nothing is dim or distorted, started it up in 20 degree weather and no problems. its all good from here!
