Old 09-27-2008, 02:24 PM   #1 (permalink)
Default HELP! Brake line 95 disco
Anyone know where to get brake lines that run from the Master cylinder/ABS to the rear axle?? I can`1t seem to find anything anywhere.
Or would anyone know the size of both lines mentioned above .
These are the lines that run down the drivers side of the disco , Mine are leaking just under the drivers door, Maybe I could just replace a section , but I`ve no idea of size.
Would really like to get new lines
JeffinIA is offline   Reply With Quote
Old 09-27-2008, 07:40 PM   #2 (permalink)
Default brake lines
try the dealer or they are 4.75 mm lines with 10 x 1.0 thread fittings and are availible from these folks at a resonable price. fedhillusa.com if you want to make them.
roverhouse is offline   Reply With Quote
Old 09-28-2008, 04:09 AM   #3 (permalink)
Thanks for the info. Maybe I can splice the line and use compression fittings
Old 09-28-2008, 10:02 AM   #4 (permalink)
pavel's Avatar
Splicing brake lines is dicey. When you consider the pressure is well over 500 psi, you had better check with the compression fit manufacturer to find out the max compression the fittings can withstand. I'm sure any brake shop can supply the a new metric brake line once you have carefully measured the length... just (masking) tape a string to the broken line to exactly measure its length and then get the shop to make you up a new line. Expect some fuss in getting the line bent to the correct shape and clipped into place. On many vehicles it is almost impossible to put new brake lines in unless the body is lifted up off the frame a bit. Check out how difficult the installation will be. If it is impossible as one length, you can get the new line made up in two pieces that will go together during the installation.
Take no chances with brakes! (old guy talking)
Visit my j**p website
Old 09-28-2008, 12:26 PM   #5 (permalink)
compression fittings are illegal are will get you into serious trouble with the law. No vehicle can pass safety inspection with compressed fitting on the brakes.
you have to use the regular type and flare the end to get it to join. Or buy it buy the foot and unravel it to the end.
if you install compression fittings and they break on yourself or someone else then you are legally liable for any and all damage. Don't do it at all
Old 09-30-2008, 05:29 PM   #6 (permalink)
OK FIxed both brake lines that went to the rear of the truck With the proper lines, Thank You all for the info. Now The *(&**()()*&^)_ Anti lock light is staying on
Brake Line Replacement FoCoRRC Range Rover Classic 3 05-08-2008 02:36 PM
wheel cylinder rebuilding theclay Series Land Rovers 23 05-21-2007 05:45 PM
help! motor running on brake line system jb1rd Discovery Series I 3 05-14-2007 05:47 AM
96 Disco brake clicking txdisco1 Discovery Series I 9 03-23-2005 12:09 PM
Best brake pads to buy for Disco I. S Couch Discovery Series I 4 09-28-2004 05:42 PM
