#16 (permalink) |
In the past I have used Mobil 1 Synthetic 10W/30 and filter. I got the oil for free. I just used it as a temporary change because I am looking at the possibility that my old oil was fouled or contaminated. But I will check out my injectors. I am going to look up my codes right now, thank God for this cheap code reader I love it! I didn't realize I possibly have an injector issue.
So a bad injector might cause this?? So if the noid light beeps the injector is good or bad? Just to clear things up: Would a bad head gasket make the truck run terrible and cause bad compression on cyl 4? Also, is it possible I might have a cyl. head problem, i.e. stuck valve or carbon buildup? Thanks again guys, keep this post going if anyone else has some advise. |
#17 (permalink) |
if a noid lite lites and flashes as the injector is constantly opening and closing then the circuit is good. if it doesnt then the injector is bad.
no headgasket problem just the injector circuit.
#18 (permalink) |
The Urban Motorist
![]() Join Date: Sep 2004
Thats the test for the injector circuit working but what if you have a corroded injector? An injector with a jammed pintle will work just as well on the electrical side.
-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=--=-==-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-= Owner of a 1996 Land Rover Discovery 1 in Beluga Black or the Dirt of the Day. Where we are going,we don't need roads. Nothing in education is so astonishing as the amount of ignorance it accumulates in the form of inert facts. ‘The Education of Henry Adams’ (1907) ch. 25 |
#20 (permalink) | |
Stock '96 Discovery
The world steps aside for those who know where they are going. .
#22 (permalink) |
Adventurous Land Rovers and Jeeps
MAF is the Mass Air Flow, measures air coming in through the intake.
Definition:A mass airflow sensor is used to determine the mass of air entering an electronically fuel-injected engine. The air mass information is necessary for the engine control unit (ECU) to calculate and deliver the correct fuel mass to the engine. Air changes its density as it expands and contracts with temperature and pressure. In automotive applications, air density varies with the ambient temperature and altitude, and this is an ideal application for a mass sensor. Yeah they are known for going out. But ECM problem can occur, especially if you are missing the rubber molding that runs along the fender sealing the hood to the top of the fender. I have also seen the MAF wiring harness damaged. I suppose that is from people pulling the intake hose and forgetting about the sensor. Most of the time when you see White smoke, you have water somewhere, from the head gaskets of in the fuel. You can take a sample of fuel and let it sit to see if it seperates, thats an easy check. Sir Chadd Rover Tech. |
| Thread Tools | |
| Display Modes | |
| Rough running TD5 | alex | Discovery Series II | 1 | 02-11-2007 10:37 PM |
| any one running 7.50-16's on disco 1 | jed | Wheels and Tires | 2 | 02-10-2007 01:09 PM |
| 97 Disco- check Engine Light on and rough running - loss of power | lajilana | Discovery Series I | 3 | 08-06-2006 08:03 AM |
| TD5 Rough Running | Richard Miller | Australia / New Zealand | 1 | 07-05-2005 02:48 AM |
| 93 Disco Engine/Auto Gearbox running hot | bobbie+chris | Discovery Series I | 6 | 04-26-2005 02:31 PM |
