HELP!! Ignition?? - Land Rover Forums : Land Rover and Range Rover Forum
» Auto Insurance
» Featured Product
Old 01-18-2013, 02:24 PM   #1 (permalink)
Default HELP!! Ignition??
I have a 1997 Land Rover Discovery. I was driving it one day and the whole thing shut down on me. They think because my key was bent that the ignition didnt recognize my key and shut it down.? Current mechanic says i 'probably' need a new ignition with key then an alarm module. Another tells me i could just replace the key. I dont have $$$ to gamble. Has anybody else had this problem??? Please help!!!!!
stargrl311 is offline   Reply With Quote
Old 01-19-2013, 04:01 PM   #2 (permalink)
glades's Avatar
If the key turns in the switch it's OK. If you can turn on the ignition (position 1 so all the warning lamps come on) make sure the the "check engine" lamp comes on. Of it does not, then it is immobilized and you need someone with a Testbook to relearn security. If the check engine lamp is on and the engine cranks but doesn't start, check the usual suspects like the crank angle sensor or the fuel pump.
If you need more help email me superwrench1@hotmail.com
"The better the 4X4, the further out you get stuck"
'96 SD
glades is offline   Reply With Quote
Old 01-21-2013, 09:58 AM   #3 (permalink)
Sounds electrical or fuel related.
If the key turned and got it started then I doubt it all of a sudden caused anything to go bad just sitting there in the ignition. Make sure you check the fuel. Your mechanic should be doing this. Have someone turn the key to Pos II while you have your ear to the floor of the cargo area. You should hear the pump run for ~5 seconds. Work from there to troubleshoot.
I'm assuming you only have 1 key?
fishEH is online now   Reply With Quote
Ignition key opens the doors and hatch but will not turn in the ignition. sanmigmike Range Rover Classic 3 08-26-2010 07:11 PM
Toasted ignition g_atchley Range Rover Classic 1 08-12-2010 08:29 PM
More Ignition Switch ronpopeil7 Range Rover Classic 0 10-25-2009 01:05 PM
ignition WPGSERIES Series Land Rovers 7 01-01-2009 10:33 AM
Ignition help norville Range Rover Classic 11 02-27-2007 04:55 PM
SEO by vBSEO 3.3.2
