discover more!
i recently bought a 1995 discovery 1 and i am havin a heck of a time getting it to run right. it threw a code 44 wich was the maf. so i cleaned it. now it threw code 48? what code is that for? and also were are all the grease points on the truck? if u can help please do! thanks!
Can't help you on the codes because ours is a later ECU system but I don't think there are any grease points. Get a Haynes manual as a starting point for service and repair.
You can check all fluids (which I bet need changing anyway) and don't forget to put the correct "knuckle pudding" in the front axle swivels. This is a lengthy job but you can get the correct grease/pudding from LR easily- about $12 per side last time I bought some. There might be a zerk fitting for grease on the drive shaft splines... Cheers. |
| Thread Tools | |
| Display Modes | |
| Netherlands Series Owner Needs Help W/ Deisel In Series | The Colonel | Series Land Rovers | 1 | 07-25-2008 01:04 PM |
| former Jeep owner now Rover Disc II owner | nurovermania | New Member Introductions | 12 | 04-11-2008 06:53 AM |
| New RRC Owner | B-More | New Member Introductions | 0 | 12-20-2007 05:43 AM |
| New Disco D2 Owner | D2 Tom | Discovery Series II | 7 | 03-17-2007 10:01 AM |
| New RR Owner | AdrianL | Range Rover Classic | 3 | 01-14-2005 08:15 AM |
