Vehicle: 96 LR Disco I 102K
Problem: While installing an aftermarket hookup for an aux. ipod input, I forgot to disconnect the neg. lead to the battery, and crossed some wires which sparked. Now, the stereo will not power up and the blower for heat/defrost/AC etc does not work. I have done the following: Checked each and every fuse at the main fusebox and the one under the hood. I also checked the fuse on the radio. All fuses are fine and I cannot figure out what could have happened. Is it possible I fried the ECU? Or what about an open wire? What are the chances there is an inline fuse somewhere I can't find that might have been shorted? BTW, I already read the Discovery Factory Repair manual and did not see anything about inline fuses or any troubleshooting information about this. ANY HELP MUCH APPRECIATED!! William ![]() |
Otherwise known as STEVE
There are no inline fuses in there... you might have cooked a common ground used by both of those systems. Yikes...
I just checked the stereo by grounding it from another wire, and NO POWER!
I am thinking I fried the stereo and the blower. I am going to test a stereo I know works and see if that does it. As for the blower, I am going to get to it and see if there is power going to it and troubleshoot from there. Does anybody have a better idea? |
