Old 06-09-2006, 09:42 AM   #1 (permalink)
Default Help! Open.Closed Loop, Please comment!
Hello All,
I have changed both front (pre-cat) O2 sensors and done a 90 k service. Am about to turn 100k miles on this 96 Disco 1 SD, US version.
I have a scan gauge and read the sensors direct. Here is the issue:
Once the engine is completely warmed up, including the exhaust manifolds, it switches to open loop operation. If I turn the engine off 10 seconds it goes back to closed loop but than switches again to open loop when fully warm again. So far I have done all my own work with friend's help.
LR mechanic says: do a 30 minute reset of the "adaption" with the testbook to get the computer back to original specs. I think this is reprograming the PROMS.
LR service writer says: replace coolant temp sensor since it goes to open loop only when fully warm.
Any opinions welcomed!
Already posted longer version under Open/closed Loop Coolant Temp Sensor but nobody responded! PLEASE ANY ONE WITH COMPUTER OR obdII EXPERIENCE LET ME KNOW IF THESE DEALER SUGGESIONS MAKE ANY SENSE.
KRMusher is offline   Reply With Quote
