Old 12-20-2006, 09:01 AM   #1 (permalink)
SkeeZness
SkeeZRoverXD's Avatar
Default help shed some light on the situation
Ok I was out wheeling last night and after about 45 min. my roof rack lights and all of my interior lights went kapoot. I'm checking the fuses today...if thats not it what else should I be on the look out for?
Thanks for any help in advance
SkeeZRoverXD is offline   Reply With Quote
Old 12-20-2006, 09:24 AM   #2 (permalink)
Where did you wire your roof lights into?
Old 12-20-2006, 09:48 AM   #3 (permalink)
Banned
Does the cigar lighter still work. How about the power seats?
Hank is offline   Reply With Quote
Old 12-20-2006, 05:14 PM   #4 (permalink)
SkeeZness
I believe they're wired in w/ the headlights but the headlights are still working its really weird
Power seats are for p*ssies lol j/k...i wish i had power seats and my cigar lighter hasn't worked since i got it
Old 12-20-2006, 05:19 PM   #5 (permalink)
SkeeZness
i didn't do any of the work on the truck so icalled the guy today who did and he told me the fuses to check but he said it was probably something to do with the switch which blows cause I'm not gonna be able to get em back working until after new years when I can get out to Danville!!!
Old 12-20-2006, 08:02 PM   #6 (permalink)
If you have power at the fuses check the CCU. Its the module behind the fuse box inside the car.
Its possible due to corrosion the unit and the wiring behind it is shot. I have seen it before. Its hard to see unless you take it apart. The connector and the ends get all corroded up and break.
Heres an ideal.
If you got power at the interior switch then check their.
Remember you have two grounds. One for the on switch which is the one at the light and the other is at the module. The module ground is the interior light ground for the door opening.
Old 12-21-2006, 06:10 AM   #7 (permalink)
96owner's Avatar
did the head and tail lights go out too. i had all my lights go out (inside and out). ended up being the light switch.
Delaware Mother******!
1996 Disco
Myspace
mods:
OME HD lift (thaks max)
zombie
96owner is offline   Reply With Quote
Old 12-21-2006, 05:00 PM   #8 (permalink)
SkeeZness
found it the f8 fuse melted...by the way can you use a bigger fuse or do you have to use the same one i.e. 20 watt
Old 12-21-2006, 08:51 PM   #9 (permalink)
Super Moderator
Disco's Avatar
You can stretch it to 25amps, but thats it. Any higher and you could end up with melted wires. If the 25A fuse blows, start looking for the cause before using the lights again.
Old 12-21-2006, 11:29 PM   #10 (permalink)
SkeeZness
thanks for the advice everybody
Old 12-22-2006, 06:34 AM   #11 (permalink)
Banned
If the fuse melted, you have a ground issue. If it's just blown, then just replace it.
Old 12-23-2006, 10:49 AM   #12 (permalink)
SkeeZness
so if it is a ground issue where do i go from there???
Old 12-23-2006, 06:30 PM   #13 (permalink)
Banned
haha, get a 12-pack and have fun!
......I would start with your light install
Old 12-24-2006, 01:49 PM   #14 (permalink)
If you used them for 45 minutes its possible they were drawing too much current for the available wire. Its not that the wiring for the lights were bad its just if in conjunction with the wires for the interior its too much.
personally like everyone stated start with the lights overhead.
Find the source where they connect with the interior lights and then disconnect the wires from there.
But seriously the guy that ran your wires really screwed up. He should be taking care of his fuck up. Sorry but he wired it. He should have had more common sense and ran a better set up. NO one here will question your decision to put in the lights. They will question why he ran them the way he did.
first and foremost I would have ran them off the high beams. Use the twelve volt signal from the high beams to run a relay which powers up the off road lights.
Use a separate power and ground for the offroad lights so there isnt any trouble. That way the high beams wont fail unless the relay goes bad.
If someone has MS paint or something similar I am sure they could draw up a diagram if you need it.
Old 12-24-2006, 04:35 PM   #15 (permalink)
You said F8 correct/
On my diagrams that is a ten amp fuse.
I see two locations of problems.
The glove box. and the Rheostat. All the other lights come after the rheostat
If pulling the glove box doesnt trip the fuse then its the other side.
You might have to pulll a few areas with the illumination from the rheostat thumb switch.
But first pull out the wiring for the Overhead lites.
That might be your first problem.
or you could throw an inline fuse with that wiring to see if it blows.
If this isnt a definite problem with a blow fuse every time the door opens or something else you are going to have bear with me and either pull out some stuff or give it back to the guy that fixed it.
