Old 03-08-2006, 08:18 PM   #1 (permalink)
LRDisco94's Avatar
Angry HELP !!! Valves are bent !
Mechanic called while i was gone and told me that the valves are bent
So is there anything i should have done while he is changing the valves ?
-LRDisco94-
www.floridalandroverclub.com
LRDisco94 is offline   Reply With Quote
Old 03-08-2006, 08:34 PM   #2 (permalink)
the only way you bend the valves on those are scewing up the timing when you take the heads off.
What did you do at all.
And when you bend them you kill the engine.
Old 03-08-2006, 08:40 PM   #3 (permalink)
LRDisco94's Avatar
the timing chain broke and gear broke
-LRDisco94-
Old 03-08-2006, 08:54 PM   #4 (permalink)
LRDisco94's Avatar
i guess im just screwed
-LRDisco94-
Old 03-08-2006, 09:19 PM   #5 (permalink)
Banned
That sucks!
But, while he has the thing tore down, get a new 3-angle valve job, flat mill if needed, and a port and pollish. The P&P will give you 35HP+ alone!
Also, contact D&D Automotive and get a double roller timing chain kit.
If you really wanted to "get-er'-done", add a new cam, too. D&D has all sizes. When I did my motor, the chain, cam and lifters was 450.00 shipped. HUGE difference! That cam and a P&P, and your going to have a badass motor that's still awesome for daily driving.
Hank is offline   Reply With Quote
Old 03-08-2006, 09:27 PM   #6 (permalink)
LRDisco94's Avatar
Originally Posted by Hank
That sucks!
thing is...he already replaced the timing chain.. he put it all back together and found out the valves were bent...... i didnt know untill after that i should of had the cam replaced.. can he order all that stuff from the shop?
**Also remember** i work part time ! and he already say its gonna be around 1200 to do the work -
-LRDisco94-
Old 03-08-2006, 09:31 PM   #7 (permalink)
LRDisco94's Avatar
im thinking maybe i should just go all out and have him replace everything...ill be in debt for a while...but got to do what i got to do
another question !!
the engine has just a little over 170,000 is it time for a new engine? whats the life expectancy with these rovers ? i know if you maintain them well they can last forever... this truck was serviced reg. and stamped in the book up to 90,000 which im guessing was sold to the 2nd owner which then went from 90,000 to 160,000 and then to me, so i dont know what the guy did between then
-LRDisco94-
Old 03-08-2006, 11:15 PM   #8 (permalink)
Magicly Delicious
Bene's Avatar
i know a guy who may have a pair of 3.9 heads laying around. shipping to FL would be a bitch though...
Kevin
1994 Discovery
Old 03-09-2006, 07:29 AM   #9 (permalink)
LRDisco94's Avatar
Well it should be all good, im just..... 1600 in the hole
-LRDisco94-
