Old 10-26-2007, 07:39 PM   #1 (permalink)
Default Help! Wife stuck 97 Disco won't start
She's actually getting a ride from a neighbor but here's what happened.
She drove in stop and go traffic for about an hour. Parked outside of a take out place.. got back in, tried to start no go.
Sounds like it wants to start and will chug for a few seconds before dying.
Lights look bright.
So I don't think it's the battery or the starter from her descriptions and sounds of the engine.
I know very little about her car, but if my VW bus was doing the same thing, I'd think that a vacuum line got pulled off, or there was a fuel delivery problem.
I would think spark is ok.
Any suggestions... fuel pump? Relay? Anything I can check to try to fix it without having to tow it to the shop?
Thanks in advance.
Wayne in Beaverton, Oregon.
IFBwax is offline   Reply With Quote
Old 10-26-2007, 10:48 PM   #2 (permalink)
Searcaigh's Avatar
Gallery: 31
First I would check the battery terminals, lights etc might work but ignition system doesnt if there is corrosion around the terminals
Gordon T. Smith
Middle East Land Rover Nutter
Searcaigh is offline   Reply With Quote
Old 10-27-2007, 10:03 AM   #3 (permalink)
So, if the engine is turning over but not starting, is the check engine light on? How many miles on the truck, when was the last tune related work done on it. how long ago was the fuel filter changed?
Old 10-28-2007, 12:21 PM   #4 (permalink)
Check engine light is not on... only about 55K miles.. real good condition.. last tune up related stuff done about 3 months ago. Not sure about fuel filter.
And here's one more clue.. She went back the next day and it fired right up.
Could it be some kind of a hot start issue?
Thanks all!
Old 10-28-2007, 01:57 PM   #5 (permalink)
Could be a dirty fuel filter or a failing fuel pump relay. Could be other things but that is a place to start. So was she able to drive it home?
Old 10-29-2007, 08:30 PM   #6 (permalink)
Yes, she was able to drive it home. Actually she started it the next day and it fired right up.. then my 4 year old daughter who was watching decided to turn the key back off. But luckily it fired up a second time.
Maybe she just flooded it.
We'll keep an eye on it and I'll investigate further.
Old 10-30-2007, 10:13 AM   #7 (permalink)
pavel's Avatar
Certainly sounds like a fuel starvation problem. On our '96 Disco, occasionally it shows similar symptoms that are related to the ignition turn on/ECU sequence. When it happens (about twice a year) all the wife does is turn off, remove the key and then start over again. She waits to hear the fuel pump sound before turning to start position. She figured it out herself! She can cook too! What a lucky guy am I ....
Visit my j**p website
