Old 08-09-2007, 08:15 AM   #16 (permalink)
rmuller's Avatar
Originally Posted by bd1308
I'm also getting worried about finding 5spd parts....
No worries.. 5spd may be unique stateside, but I'm sure it's not overseas.. and thats where the rest of the parts come from anyways.. if you can't find it on atlanticbritish.com, roversnorth.com, etc.. they can probably get it from their suppliers.
Old 08-09-2007, 10:40 AM   #17 (permalink)
Personal opinion, don't use ATF. Use a good engine oil flush product and follow the directions on the bottle. Then use a good quality, High detergent, motor oil and do frequent oil changes for a few months.
"Your only supposed to blow the BLOODY DOORS OFF" The Italian job 1969.
roverandom is offline   Reply With Quote
Old 08-09-2007, 10:52 AM   #18 (permalink)
Originally Posted by Rovin4life
a compression test tells you what cylinder is bad, a cylinder leakdown test fills the bad cylinder up with airand you then listen for the sound of escaping air. had a guy with a bad injector that hydrolocked the motor and scrapped the lower cylinder walls.
Ive seen a combination of factors including misrouted belts that can cause low idles to a point the oil light comes on. very rare but get someone that screws up a bit with a few other factors and it has happened. of course, of course if you dad dont like changing the oil and the sludge hasnt killed the pump then it could be a possibility of something worse.
A compression test, tests the ability of a cylinder to compress air, nothing more. You have to find the cause of a low compression situation by other means. A cylinder leak down test needs a special gauge to tell if excessive leaking has occured, not just listening for escaping air (although you should do that also). Interesting about the missrouted belts causing low oil pressure!
Old 08-09-2007, 12:59 PM   #19 (permalink)
pavel's Avatar
bd1308: what's the condition of the body and frame? Even though you got this Disco for free, at 200k miles she's ending the autumn of her life. You could easily spend a ton of money on her for very little return. Don't get me wrong, the rebuild process could be fun and very educational. Just do a careful cost/benefit analysis. What about going exotic and putting in a good used Mercedes 300 turbo diesel - I believe they fit.... meanwhile could you drive the 'Old Man's '04 occasionally?
Visit my j**p website
Old 08-09-2007, 01:44 PM   #20 (permalink)
Rocky Mountain High
Funrover's Avatar
Hey quit telling my ideas!! LOL
Old 08-09-2007, 06:48 PM   #21 (permalink)
Forward!
Badger1's Avatar
Gallery: 1
Plenty of places to find 5speed parts. As for motors you could find a low/er mileage GEMS motor and just swap it out, or rebuild it. Plenty of parts and suppliers out there to do a rebuild, and while your at it you could swap in a hotter cam for a bit more oomph.
As for keeping the truck, hell I would keep it just for the sentimental aspect, not to mention it is pretty neat having a 97 D1 in a 5speed. As long as the frame is in good shape, your sitting pretty, if not find yourself a donor truck with a good frame and swap. That was done on my wifes D2(albeit by the dealer under warranty )!
http://www.landroversonly.com/forums...sc-sale-27618/
1997 Disco 1
2000 Disco 2
1989 RR(gone but not forgotten )
Miami Valley Land Rover Society
www.mvlrs.com
ON WISCONSIN
Badger1 is online now   Reply With Quote
Old 08-09-2007, 09:18 PM   #22 (permalink)
Drove it today, the ABS light was lit and I felt something like pads were gone, so i'm goign to look at that tomorrow.
bd1308 is offline   Reply With Quote
Old 08-09-2007, 09:21 PM   #23 (permalink)
Body is in great shape, most suspension parts already rebuilt.
I learned 5spd on a 1974 Porsche 914 (my previous car), I now have a mazda protege to drive everyday, the disco is a project/fun car.
Dad broke the rear window for the third time....I saw something on discoweb about repairing teh rear window regaulator piece by using nylon washers?
Old 08-09-2007, 09:54 PM   #24 (permalink)
Forward!
Badger1's Avatar
Gallery: 1
While your doing brake pads, you will also want to renew the brake fluid too. With the amount of miles you might want to replace the flexible brake lines with braided ss ones.
1997 Disco 1
2000 Disco 2
www.mvlrs.com
ON WISCONSIN
Old 08-10-2007, 07:41 AM   #25 (permalink)
well that mercedes 300 engine sounds intresting, but i'd really prefer to stick with the rover engine for now. I suppose my arm could be twisted if there was a substantial increase in mileage, but that rover engine does sound cool.
