Originally Posted by greg409
Did I wonder about that on another site to you?
Also, I bought NTK brand o2 sensors for my '97 several years ago - spliced same color coded wires into the harness.
they were around $40 ea I think & work fine
luck,greg
good call on the 02 sensors.
maybe on a different forum. i tend to double dip when i need help asap. like this thread
so i got the misfire issue taken care of. stupid me, assumed plug wires were good when they werent.
now, however idles higher than ever (2500ish) i have taken IAC and TPS off and cleaned them both really good. is that little plunger from the IAC supposed to move. it wiggles a little.
also, took the intake hose off and cleaned out throttle body really well. paid extra attention to the little holes inside.
have chased vac lines all over with propane and carb cleaner- no leaks anywhere.
base idle reset? is it possible to do without a T-4 or something like that?
