1998 auto D1 w/ 185k
2nd owner (bought with 160k 1.5 yrs ago) Replaced: brake switch cooling system (minus rad) u joints in rear D-shaft VSS resoldered window and sunroof ECU added rear jump seat tires wheel bearings Hoping to hear some great stories about high mileage discos! Kieran |
Support Our Troops
1997 Disco SE7
3rd owner brought in Feb. 2005 with 104,000 current milage: 138,750 Replaced: head gaskets power steering hoses Sitting in the garage waiting to be put in: 3" Big Blue springs, pro comp shocks, trailing arms, balanced front driveshaft Still running strong and I dont baby it
John Conklin LRO Moderator |
#3 (permalink) | |
Mostly Harmless
1998 auto LSE D1 w/102K 2nd owner Given knowledge by Disco Mike... .....it runs great...but still an electrical headache sometimes w/a few lights. |
1994 Disco 1 170,000
1st owner followed the book with services all the way to 90,000 2nd no records of anything 160,000 3rd new paint, tires, roof rack, brush guard 4th Me Timing Gear was wore down and the chain broke...causing to bend the valves and i need some rebuilding of this and tht... so other things here and there replaced the wheel bearings, new springs and shocks.... i never soldered my window ecu....umm replaced the radiator and belts... other than that it runs good now i love my rover! sometimes it can be a pain But i would definatly check out your timing chain if it hasnt been changed and ur gear... |
on, off, on, off, on...
180k +. Other than the previous owner totally mucking up some re-assembly after a "rebuild" and not adding fluid to the t-case, I've had no big issues. Of course I've only put about 5k on it myself. Knock on wood.
03 Disco w/CDL 95 Disco 98 Disco: my first (gone) |
98 Land Rover Disco... with 168K miles.
Totals repairs: Steering Gear box (DIY) Idle air control valve.... made no difference with idle issue DIY Throttle sensor.... made no difference with idle issue DIY Outside of usual maintenance that is all. DIY My vehicle has not been touched by a paid mechanic since Rover did the last scheduled service back around 30K miles. Damn I am starting to appreciate this vehicle.
That is not a leak! That is undercarriage rust inhibitor. 98 Discovery |
Getting the mud off.....
'98 Disco w/ 108,000.....on the trail often
Love this truck 1st owner babyed to 80K 2nd owner (me) babyed w/ maintenance Repairs other than mainenance & upgrades: replaced the fuel pump Hasn't been seen by a paid mechanic since first owner. '96 Disco w/ 90,000 miles.....also on the trail Love this truck too. 3rd owner (me) babyed w/ maintenance Repairs other than mainenance & upgrades: new R380, new clutch & new coolant overflow tank Hasn't been seen by a paid mechanic since second owner. I came to LR via the Series trucks (have 3) and never considered Discos till the wife wanted one.................love them now (sad to see the direction they're going). JMO
’61 IIA 88 | ’63 IIA 88 | ’69 IIA 109 Carawagon | ’98 D1 | ’96 D1 5spd |'97 D90 |
Magicly Delicious
1994 auto 152k
front ujoint took the solenoid out of the transfer case put in a used tranny in November routed the belt properly ( )put in an MSD coil redid the exaust and I think 1 or maybe both of my O2 sensors are bad. I hope I never have to sell her
Kevin Owning a Land Rover is like dating a super model. Sure she has expenive tastes, complains a lot, and requires constant attention... but damn... 1994 Discovery |
#10 (permalink) |
94 DISCO 1
YOUR RIGHT I HAVE A 1994 DISCO SHE IS THE BEST AT EVERYTHING BUT SHE COST I HAVE REPLACED IN THE LAST 3 MONTHS GAS TANK FREE DUE TO RECALL.... WATER PUMP,BELTS .FAN CLUTCH,FAN,wheel bearings,PLUGS WIRES...BUT I LOVE HER SO ....141,000... I'M THIRD OWNER FIRST GAVE SERVICE TO 80,000 AT ROVER IN COLORADO...SECOND OWNER RECORDS AT DALLAS ROVER TO 110,00... THEN I BOUGHT HER HAVE ALL RECORDS HOPE SHE RUNS FOREVER...
#11 (permalink) |
1994 Disco I, auto, 387,000 miles, with me as the original owner. It's my DD, almost exclusively highway miles. Original motor, running Mobil 1, changed every 3 to 4000 miles with a dab of Z-max added. Going through engine compartment now and replacing all the rubber, while I save up money for some new front seats.
phil |
#12 (permalink) |
why do i not believe that?
Best 4x4xFar 97 Green D1 3" BB springs pro comp es9000 shocks 32x11.50 BFG Mud Terrains 15" american racing steel wheels flowmaster 40 series dual pipes mantec snorkel |
#14 (permalink) | |
Elephantitis penisitis
List the mods....![]()
#15 (permalink) | |
2002 Discovery II SE 1999 Range Rover P38 HSE |
