Old 10-17-2005, 12:45 PM   #1 (permalink)
Default How can I access the A/C fan speed switch ?
97 Disc. SE7
Hello,
How can I access the A/C fan speed switch in the center of the dash?
I was able to remove the 2 (knobs) temp. controls and the screws behind each.
I also removed the bottom trim plate that has the switchs, (on the left)
ashtray and pop-out cup holder.
The complete A/C cluster does not appear to be removable from the front.
That's as far as I could get.
I know I can repair (or replace) the fan switch if I can get to it.
Any help is appreciated.
Thank you.
stu
stufla is offline   Reply With Quote
Old 10-17-2005, 01:46 PM   #2 (permalink)
frickjp's Avatar
Ashtray, clock, cruise switch pack and changeholder gotta go. Pull the radio, 2 screws behind there. Pull the lower cupholder, 6 screws. One screw each behind clock and changeholder. Four screws at the corners of heater controls. Whole centre panel comes off. Working from behind, remove fan switch. Easiest to unplug A/C/Recirc/Rear A/C first. Fan switch is now sold with the whole panel.
frickjp is offline   Reply With Quote
Old 10-18-2005, 07:44 AM   #3 (permalink)
Default Your help is appreciated.
Many thanks to the Shop Foreman, Land Rover Amherst.
stu
