Old 01-06-2008, 09:49 PM   #1 (permalink)
Default How to change water pump
can anybody tell me a step by step procedure to replace a water pump on a 98 land rover discovery LE
98disco owner is offline   Reply With Quote
Old 01-07-2008, 04:18 AM   #2 (permalink)
Elemental's Avatar
Amazon.com: Land Rover Discovery Workshop Manual: 1995-1998 (Land Rover): Books: British Leyland Motors
Link to Step by step for Water pump and other operations.
Old 01-10-2008, 08:52 PM   #3 (permalink)
LANDY96's Avatar
Originally Posted by Elemental View Post
It's really easy! 2hr job, start -to- crank up!
Much easier than my RRC!!!!
Eric The Red
93 Range Rover Classic
96 DISCO SE7 5-SPEED SOLD
96 DISCO SD 5-SPEED
-ARB Bumper
-OME 2" Lift
-2" spacers
-Safari snorkel
-15" steelies
Old 01-16-2008, 03:16 PM   #4 (permalink)
cskone's Avatar
well, here's a quick synopsis:
-buy new water pump/gasket...might as well get a new belt while you're here
-take fan shroud off
-remove belt
-remove f*cking SOB fan
-drain radiator
-unscrew bolts surrounding water pump
-scrape all of the old gasket off
-put new gasket on (use "make-a-gasket" as well)
-screw bolts back in (using the "opposite" method...like you would w/ tire nuts)
-put f*cking SOB fan back on
-put new belt back on
-fill radiator
If this sounds really simple, it is. It's a relatively easy job...you don't need to buy the workshop manual. I actually have it and didn't need it at all
Skoner
cskone is offline   Reply With Quote
Comments/Suggestions [Post Here] rmuller Tech & DIY 29 04-20-2007 06:33 PM
[Off Road Driving] Wading Disco Tech & DIY 0 02-14-2007 04:02 AM
[ALL] Detailing FAQ's + Technique Disco Tech & DIY 0 01-08-2007 03:31 AM
Off Road - Wading Disco Off Road 4 08-17-2005 03:19 PM
Off Road - Water Crossings Disco Off Road 5 08-15-2005 08:16 AM
