How to: Compression test? - Land Rover Forums : Land Rover and Range Rover Forum
post #1 of 9 (permalink) Old 02-05-2009, 12:28 PM Thread Starter
Poseur, Rice Boi
Quoted: 0 Post(s)
Can anyone give me a walk through on how to do a compression test? Ive got everything needed, but I have never had to do one before, so Im really gonna need someone to break it down barney style, and give me a step by step. Also, what are ideal numbers that Im looking for? Its gonna be done on a 97' Disco I, with 131XXX on her.
Thanks
DeadHead86 is offline
post #2 of 9 (permalink) Old 02-05-2009, 01:05 PM
Lake_Bueller's Avatar
Quoted: 0 Post(s)
I've never done one on a car or truck but have on a motorcycle.
Simply pull the plug wires, insert the tester in the plug spot on the cylinder being tested, crank motor, check readings.
What you want to do is get the pistons to move but not actually run the motor. That's the reason behind disconnecting the plug wires.
The influence of fine scenery,
the presence of mountains,
appeases our irritations
and elevates our friendships.
-Emerson
Lake_Bueller is offline
post #3 of 9 (permalink) Old 02-05-2009, 04:03 PM Thread Starter
Poseur, Rice Boi
Quoted: 0 Post(s)
Do I need to disconnect any grounds, wires or the computer or anything like that?
post #4 of 9 (permalink) Old 02-05-2009, 06:51 PM
rmuller's Avatar
Quoted: 0 Post(s)
Pull plugs, cut off fuel pump/injectors, and insert compression tester and crank... I believe numbers are supposed to be around 170'ish ... and should be around +/- 10% of each other.
Ryan ::
2001 Discovery II | 2006 LR3 HSE7 | 1994 Defender 90 #416 (Gone)
rmuller is offline
post #5 of 9 (permalink) Old 02-06-2009, 12:12 AM
Ian Matthews
p76rangie's Avatar
Quoted: 149 Post(s)
First off, why are you doing a compression test?
Warm up the motor to running temp and then switch it off. Pull all the plugs and disconnect the power to the coil. Put the compression gauge into each cylinder and get someone to turn over the motor, while holding the throttle flat to the floor. Watch how the gauge increases its reading. It should get close to its maximum within 2 to 3 turns of the motor. Keep on turning over the motor until the gauge stops increasing.
The compression reading will change depending on whether you have a high compression or low compression motor and a number of other factors. Anything above 130 psi is serviceable. But as already pointed out, you are mainly looking for differences between the cylinders.
A vacuum gauge will tell you more about your motor than a compression gauge.
p76rangie is offline
post #6 of 9 (permalink) Old 02-06-2009, 04:13 AM
antichrist's Avatar
Quoted: 3 Post(s)
Additionally, remove adjacent plugs together as a head gasket leak between cylinders can be masked if you don't.
If you have a low reading, a couple of squirts in to the cylinder can help isolate the problem. If the pressure comes up retesting after adding oil, it points to worn rings/cylinder wall. No change points towards a bad valve.
Tom Rowe
Atlanta, GA
62 88 reg
67 NADA x2
74 Lightweight - The Antichrist (tag 6A666)
95 D1 - R380
95 D90 - R380
97 D1 - ZF
antichrist is offline
post #7 of 9 (permalink) Old 02-06-2009, 06:01 AM Thread Starter
Poseur, Rice Boi
Quoted: 0 Post(s)
Well p76rangie, Ive been have problems with power with my rig. I only really experience it at speeds above 50 to 55, and sometimes are better then others. im not loosing any coolent(if I am, its very slow), and I dont believe that I have any coolant in the oil. Ive already cleaned the MAF and butterfly valve, as Im pulling code P1194. Im pretty sure the power lose is due to either a bad o2 heater or o2 sensor. Im pretty sure the cat is now blown as a result. Im just having the entire exhaust system replaced... It was needing it anyways and I dont feel like trying to solve the mystery. I just wanna do a compression test to be sure its not due to a head gasket leak or something similar.
Thank you everyone for your advice! I have to tell ya, this is probably my favorite forum, def the most responses.
post #8 of 9 (permalink) Old 02-06-2009, 06:04 AM
Quoted: 0 Post(s)
Here's a couple good links on compression & vacuum testing.
Compression Testing
Using A Vacuum Gauge
Hypothetically speaking... say your "friend" did a compression test and forgot to hold the throttle open, how would this effect the readings???
Kevin
88 RRC "Audrey"
Kevin88RRC is offline
post #9 of 9 (permalink) Old 02-06-2009, 07:36 AM
Ian Matthews
p76rangie's Avatar
Quoted: 149 Post(s)
As the main thing you look for is the difference between the cylinders, not having the throttle open for any of the readings would not make that much difference.
If you actually want to get the proper PSI, not having the throttle open will restrict air into the cylinders and will give a slightly lower reading.
Putting oil in the cylinder can increase the compression when it is a valve as well and in a V8 it is difficult for it to have the right impact on the rings due to the piston being at a angle.
As already indicated, a vacuum gauge will tell you a lot more about the state of your motor than a compression gauge.
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
User Tag List
Linear Mode Linear Mode
Im about to let my disco roll down the driveway and get hit by a mack truck greenmountainski Discovery Series I 9 09-24-2009 05:12 PM
Code 48 - What does this mean? UsedBlue Discovery Series I 6 04-17-2008 11:40 AM
245,000 mile Compression Test skippermccoy Range Rover Classic 2 11-04-2007 08:46 AM
Compression test monkey_james Range Rover P38, Mk III and Range Rover Sport 0 05-07-2007 12:05 PM
Discovery Tech Questions 62sunbeam Discovery Series I 9 12-22-2004 09:05 AM
You may post new threads
You may post replies
