How to: Get your Diff lock un stuck. - Land Rover Forums : Land Rover and Range Rover Forum
post #1 of 17 (permalink) Old 07-14-2010, 10:24 PM Thread Starter
gtr
60% of the time it works sometimes.
gtr's Avatar
Quoted: 0 Post(s)
Cool How to: Get your Diff lock un stuck.
Now I searched around trying to fix mine and no one really posted a for certain how to on how to get your diff lock un siezed. This normally stems from lack of use. This can also happen where you try to use it for the first time and it sticks up while engaged like mine did and your left screwed
So this is how I fixed me diff lock. It worked well.
Details 1997 Land Rover Discovery Series 1 216,000kms. Been stuck in diff lock FOR TWO YEARS! Truck has been in the water, mud, snow everything and anything truck has driven through. It was stuck in there when one of the fron half shafts broke, and do get them home he had to ram it into diff lock.
Step one: You realize your diff lock does not work, you begin swearing, yelling, pulling, kicking, shouting and generally being quite rude to the small lever below your cup holders. You go home and say Ill do it tomorrow.
Step 2: you come back and see that it is siezed. Begin by dis assembling the center console. For mine there was a rubber mat I pulled it up removed the boot from the e-brake and the diff lock shifter. Under what I believe is four screws, two on the console near the shifters, and two in the center console. Then grab your e-brake and pull it up as hard as you can. lift the back of the console and guide the e-brake lever. Great you got the console off and your starting to see things. Remove the foam boot and what you should be left with is an exposed rubber boot covering the diff lock shifter.
Step 3: Grab your drill, drill out the rivets that hold the rubber boot in place. once you have lift it off, should have the shift knob already off, now you have exposed your linkage. This is a good start. But the problem normally is not the linkage its the actual shaft in the housing of the shifter, you can spray it with some WD40, deep creep, free all, human semen, blood, tears, and a little bit of margarine. But if your really stuck (which they normally are, this does nothing.
Step 3: remove the bezel around the automatic shifter, remove the plastic cover on the handle, remove the small metal clip with a needle nose pliers, remove the plastic piece that slides when you press the button, put a 19mm socket on there and loosen the bolt inside, and then tug on it till it comes off. (from experience do not stand over it you will hit yourself in the face) lift the plastic cover off. you have exposed it a bit more, you will see 4 Philip head screws, this is a different type of Philips though PZ something Philips may work but it may begin to skip. once that is done you will notive it has become free and you can almost take it out. BUT WAIT THERE IS MORE!.
Step 4: See more rivets under the edge of the carpet on both sides, drill those bad boys out. and lift the metal housing for the auto shifter a bit and you will have enough room for the last one hiding half way under there, drill that out and lift the entire thing up, take the metal plate and pull it towards the dash board and remove it, the housing to the auto shifter is connected with a cable. It is not needed to be removed, just cover it with something so any debris does not fall inside and cause you problems later.
Step 5. to the right of the diff lock shifter is a rod that has a fulcrum point against the transfer case, at the top where it connects to the shaft then connects to the handle you will see a metal spring clip and a pin, remove the clip, take a small brass punch and hammer and begin tapping it, it should come out (DONT LOOSE THAT PIN!) now remove the the 4 bolts on top of the housing next to the diff lock shifter. 3 14's and 1 12mm I believe. Awesome sauce. Now to confirm that its the actual shift take the hammer and tap the linkage in and out of diff lock it should move relatively freely, this normally does not seize. Now take that pain in the ass piece of technology to your work bench!.
Step: 6. Read the following diagram and dis assemble the shifter, but you will notice that the rod is seized in the small housing circled. Great now what should I do, should I give up on life, light the truck a blaze and buy a toyota tercel? First of all dont say stuff like that people will think you have problems. You take that and try and position it in a way where no pressure it placed on the aluminum housing or that piece the shaft goes into, take a big #3 philips and remove the screws, get your punch position and get to tapping with the hammer, you should get a bit of movement, spray some deep creep WD40 or w.e you use on it, let it sit, flip it over tap the shaft back, spray some more let it sit. Wait. Tap it back out, get some light sand paper clean up any corrosion, and tap it again, it should come out, and remove the shaft, awesome now clean it really well with sand paper both that and the fitting it goes into. Once that is done spray it some more with wd40 for good measure.
Step 7: take some grease, put it on the shaft and in the fitting and re assemble, pack the shifter housing with grease and later that side with some for good measure, bolt it back in put the clip back and rod and give it a whirl, it should work better then new, do it 20-25 times to just make sure its working, re assemble it make sure to get a rivet gun and install new rivets and everything the way it does. re assemble, and give it a try you should have a properly functioning diff lock lever, and make sure to regularly pull it in and out at least once a weak to keep things moving.
Hope this helps, thanks for the guidance with other issues I have had guys, your knowledge really did help and I wanted to give back to the community.
What will you do with a properly working center diff?
I will do...
Thanks guys happy wheeling!
1997 Land rover Discovery.
Safari Guard Bumper w/ skid plate, front and rear diff guard, transmission skid plate, gas tank skid plate, Super winch 9000LB winch. Hella 3000 off road lights, cd changer, Somewhat working, well see how that goes.
1990 Nissan Skyline GTR. *Engines fried, time to start over*
gtr is offline
post #2 of 17 (permalink) Old 07-15-2010, 03:03 PM
greg409's Avatar
Quoted: 0 Post(s)
Very nice, gtr
Your truck looks red on one side and white on the other, cool!
luck,greg
'96 RR SE - sold dammit
'97 D1 SE7 - I'll be buried in it
Like Flukey
Some bushings, Ford injectors, airtex fuel pump, timing chain , valve covers, crankcase scraped clean, side exhaust, twin 4" 110watts on bumper, sony, twin 12" electric fans, timing chain, guages, waterpump, no front sway, cut off front apron, 245/70/16 sumitomo all-terrains, front shock towers, shocks, starter, alternator, window reg mod, clean MAF, autolite plugs & autozone wires 50k and counting, front hubs, rod bearings, freed CDL, balljoints, Sony sound, u-joints, etc.
Don't ever give up - It's only a machine!
greg409 is offline
post #3 of 17 (permalink) Old 07-22-2010, 07:17 PM
Quoted: 0 Post(s)
GTR,
Thanks for the info. I haven't been able to shift into 4L or lock the diffs. I was considering my options, hoping it would be something between the shift knob and the transfer case, since even rebuilt ones are $800+. I'm going to rip into mine once I finish in the engine compartment. I'll let you know how it goes, hope I'm into 4L in no time.
CT1997D1 is offline
post #4 of 17 (permalink) Old 07-22-2010, 10:42 PM Thread Starter
gtr
gtr's Avatar
Quoted: 0 Post(s)
Good luck CT, Take it apart, the units are very old and seize up as it is a steel shaft in an aluminum housing and seize up quite easy. I modified mine a bit, I used parts from an older Range rover or defender I think. It has a rubber boot instead of that stopper plate. Now if yours was off roaded like mine dirt got caught up in it. With the new parts its packed full of grease and is sealed with a rubber boot so no water or debris can get in there and the grease is always clean.
Good luck.
gtr is offline
post #5 of 17 (permalink) Old 07-23-2010, 06:26 AM
Quoted: 0 Post(s)
Great write up. sounds exactly like the problem I have on my to do list
Thanks again
whiskyb is offline
post #6 of 17 (permalink) Old 04-01-2011, 05:57 AM
Quoted: 0 Post(s)
Absolutely brilliant instructions. After two years of not working, well on the way to be fixed!
Paul
paulgkn is offline
post #7 of 17 (permalink) Old 07-03-2011, 09:05 AM
Quoted: 0 Post(s)
If this works on my RRC, you're my hero.
Mine has been stuck in 4HI since who knows how long, thanks for this!
Hamal T.
1994 Range Rover County LWB - Sold for Parts
1999 Disco II, 98k, Stock
1999 Kawasaki Ninja ZX-6E - Summer ride to work.
1994 Ford Taurus SHO - Modded Q Ship.
Racer X is offline
post #8 of 17 (permalink) Old 07-03-2011, 11:38 AM
Quoted: 12 Post(s)
Your Range Rover's inability to shift from high to low is not the same as the problem in this writeup. You probably have a bad solenoid.
Paul Grant is offline
post #9 of 17 (permalink) Old 07-03-2011, 12:33 PM
Quoted: 0 Post(s)
The solenoid has been modified, as it had seized in the locked position. It's now permanently unlocked. That said and done, I still cannot shift into 4LO.
Hamal T.
Racer X is offline
post #10 of 17 (permalink) Old 07-03-2011, 12:41 PM
Quoted: 11 Post(s)
The solenoid on your '94 should be able to be completely removed. It's likely held to the transfer case shifter by two socket-head cap screws.
Yes, I am still alive, and still in the Rover parts business.
Text me for greatest likelihood of finding me.
260-804-0458
Dominic Perodeau/Global British is a thieving bastard, do not send him money.
PTSchram is offline
post #11 of 17 (permalink) Old 07-03-2011, 01:01 PM
Quoted: 0 Post(s)
The solenoid I found was bolted to the base of the transfer case shift lever by two cap screws, with a 6mm socket head. The lever had an extension that extends into the casing of the solenoid, a pin would extend to block the lever from moving one way or another. That pin was permanently retracted.
Even with the solenoid not attached, I still couldn't shift out of high range.
I swear, sometimes I wonder if the PO left the truck parked in a saltwater pool or something. There are things rusted on this rig that I never could have imagined would ever rust. And yet, here we are.
Hamal T.
Racer X is offline
post #12 of 17 (permalink) Old 07-03-2011, 01:40 PM
Quoted: 11 Post(s)
OK, try disconnecting the linkage that goes from shifter to transfer case, try to move the shift lever. If the shifter moves freely, the problem is in the transfer case, if not, it's the shifter mechanism.
260-804-0458
PTSchram is offline
post #13 of 17 (permalink) Old 04-08-2014, 04:38 PM
Quoted: 0 Post(s)
Hi. I have just joined this website. I have a 94 landrover discovery 1. And i have a question about this post. My diff lock is locked in, and shifter will not move. It is stuck in 4 wheel high though. So would i still follow the above directions. I love my truck, and this website has been great and very informative. Thanks again . Any comments or advise is much appreciated
bkdiscovery is offline
post #14 of 17 (permalink) Old 05-21-2014, 01:02 PM
Quoted: 0 Post(s)
just did this yesterday on my 97 XD. worked like a champ. Its actually much easier than it appears by reading the write up!
weaksauce is offline
post #15 of 17 (permalink) Old 06-25-2014, 05:39 PM
Special Agent
redtruck12's Avatar
Quoted: 93 Post(s)
Garage
Hi recently bought a 1996 d 1 shifter is seized up solid. Working on getting it apart and have a couple questions
1 auto trans. Shifter knob just pulls off like my D2 or is there a clip I'm missing?
2 the steel plate under the shifter looks to go under the heater box. Does it? I have the boot off around the 4wd shifter but until I get the shifter knob off I'm kind of stuck.
3 the shift rod for hi Low. How is it attached?
Any help or direction would be great
Happy Happy Happy
2004 D2 se5 (sold)
2001 D2 se5 (parts truck)
2000 D2 se7 (retired)
1997 D1 (sold)
redtruck12 is online now
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
User Tag List
Linear Mode Linear Mode
97 Discovery Almost done. Racing idle in P/N, stuck in diff lock gtr Discovery Series I 14 07-14-2010 09:33 PM
Diff. stuck in 4H LanceRR Discovery Series II 2 05-12-2010 12:49 PM
Diff Lock won't engage (not stuck lever) tomw Discovery Series I 9 12-22-2009 11:08 AM
centre diff lock stuck on paulmartindefender Defender 0 10-27-2009 06:58 PM
Diff Lock Drewfuss Defender 11 06-13-2005 06:58 PM
You may post new threads
You may post replies
