Hi everyone, here's my story...
I bought a Disco for real cheap, I had to trailer it home cause it was puking gas from on top of the gas tank when running. (a little dangerous... Don't you think)
Had to cut the two hook loops from the back frame rails and drop down the rear sway bar to get the gas tank out. Once that was done I pulled the rear carpet etc to access the hatch. The screws that held it on were so badly rusted that there was no way they were going to come out so I hit one with a brass chisel and the whole plate fell out!
I'll post picks of the hatch fix after.
Put a Mic on the line and found some replacement line after removing the rusted off lines. Did some bends with the proper bending tool from princess auto and pressed them into the top of the plastic sending unit top. (had to dis-assemble the entire unit to do this)
Got new Clamps re-assembled the unit and reclamped the plastic gas lines, then after cleaning the entire tank... re-installed the unit.
Dirt buildup and water sitting on top of the tank was the cause of the rusted lines so I plan to coat the area with grease before I close the whole thing up.
Hope these photos may help someone in the future...
Visit my ebay stor if you have time,
Untitled Document
Thanks
