Okay. I have two issues, they may or may not be one issue, I dunno if they're related. First, when my blower motor was on high(position 4), it would mostly work normally, but occasionally it would cut out. When it cut out, a gentle tap to the blower motor switch would get it to cut right back in. A couple weeks ago, it started cutting out more frequently, and sometimes it would come in and out very rapidly, to the point where I could hear a relay clicking in the right-hand footwell.
Issue two; when I heard that, I started just leaving the heater in position 3. After about an hour of driving, I apparently lost all power to the HVAC system. My Recirc light went out, even though it was on, AC light wouldn't come on, and the blower motor cut out. I turned the whole system off, and a few minutes later, it came back on. This cycle repeated for two days, before the HVAC system just lost all power and never came back. I checked the fuses in the dash box, and they were all good, so I'm at a bit of a loss of where to look now. Advice?
1-thats normal for the DI, dont use 4th on the fan speed.
2-the switch overheated, dont use 3rd on the fan speed for long periods.
Remove the HVAC control panel, take the fan switch out and clean it, rough up the copper contacts with a emery cloth, clean again, put it all back.
2nd owner of a '97 Disco with a ARB winch bumper, SD roof rack, Rover Racks ladder, Cooper S/T's and 220,000 miles on the clock and still a daily driver.
Okay, I did this just now, contacts were very dirty and pitted in a few places, cleaned them up to shiny new copper with emery cloth, but nothing changed.
As it stands, I don't appear to have power to my HVAC system. The Recirculating button doesn't light up when engaged, regardless of blower switch position, and I don't have blower on any setting. Where should I go from here? Is there a relay that powers it? Or is it just fused? Is it just the fuse under the steering wheel, or is there another I should look for?
Thats all I got man, sorry.
When it comes to electrical stuff I can change a light bulb if someone helps me, otherwise I'm useless.
There is a fuse box under the hood, I do not know if that has any fuse for the HVAC or not.
I assume you checked the fuses under the dash.
It sounds to me like a blown fuse or bad relay, check the a/c fuse too.
Checked all the fuses, they're all good, I'm trying to check relays now, but I have no clue which one is the HVAC relay.
I dont either.
Have you checked the RAVE repair manual?
Its a free download.
In the Rave it has all the relays, inline fuses, solenoids and narrative. It has wire diagrams, location tables and pictures where everything is located. Depending on how you have your Adobe Acrobat Reader set up the Rave can be very easy to use. Forward and Back buttons, Page Up and Page Down buttons and a Search box with "Find Previous" and "Find Next" buttons helps. I used to be a Unix server admin, electrical shop forman and years of military electronics training so I have all the tools anyone could want.
I believe you'll want to check an inline fuse (blade type like what's under the dash in the main fuse panel). It's located in the wire loom in back of the blower motor. It's 10A and it's for the air recirculation solenoid which activates a damper.
If you have the black cardboard facia mounted under the passenger side of the dash it's above that so you'll have to remove the facia.
There's 25 pages in the RAVE on the blower controls and how to trouble shoot them - you should do some reading
Good luck!
Thanks, I was in the process of downloading it when I posted that. For some reason, it was taking forever to download.
Originally Posted by Spike555
I dont either.
See above, I'm working on it.
Hope that kinda helps....
Quite a bit, I'll start looking around for that fuse, then go from there.
