Old 09-28-2005, 06:39 PM   #1 (permalink)
Default i can't get out of park
i can't get out of park and my brake light won't come on. what might be the problem and how much would it cost to fix or could i do it myself
blinksalomon is offline   Reply With Quote
Old 09-28-2005, 07:10 PM   #2 (permalink)
Elephantitis penisitis
https://www.expeditionexchange.com/genuine/
Scroll down to brake switch..... always carry an extra. UPS, DHL, and USPS do not deliver to the Rubicon....FYI
Old 09-29-2005, 02:15 PM   #3 (permalink)
AAXD's Avatar
Gallery: 1
My 93 RRC went through three brake light switches in one week, I finally ended up disassembling the shifter assembly to the point where I could move the lock out solenoid by hand to shift out of park, i rigged a toggle switch to the brake light wires to control the lights until I could diagnose what the problem was. hit brakes, reach down and flip switch, let off brakes, reach down and turn off switch. It was a pain to drive like that but it got me around for the time being. Turns out the switches were faulty because the fourth one has been in there for 2 years with no problems.
Old 10-11-2005, 05:37 PM   #4 (permalink)
Default Stuck on No Go
This happened to me. It was an easy fix. I had to pop off the wood piece on top of my shifter. In there is a piece that engages a latch. This latch allows the shifter to move forward and backward and must be elevated to move. In my rover, the brad the fastened the latch to the thumb depressor had come off. Simply place it back on (I super glued it after several times popping off while in reverse of all gears) and put the plastic top on the shifter. Hope that helps.
marteeth is offline   Reply With Quote
Old 10-11-2005, 06:08 PM   #5 (permalink)
4x4 Adventure Gear
John C's Avatar
Marteeth, the same thing happened to me but if his brake lights don't work than it's the brake switch.
We have the brake switch in stock but if you need to fix it right away you can bypass the switch by jumping two of the wires. I can't remember which one but you can check on Dweb for the information.
Good luck.
John C
1996 DI - 3" AG lift
1990 Kawasaki KL650B Tengai
1989 Kawasaki KLR650
Old 10-15-2005, 07:32 PM   #6 (permalink)
frickjp's Avatar
Go to the rear door and open it. Look at the passenger side of the glass. See the two terminals there? One is power for the rear glass heat, the other is power for the 3rd brake light. Drop a quarter in there to short the two terminals together. Turn on the rear glass heat, it powers the brake light/shift interlock circuit, shift out of park. Works in a pinch.
frickjp is offline   Reply With Quote
Old 10-15-2005, 08:03 PM   #7 (permalink)
Rocky Mountain High
Funrover's Avatar
Never saw that coming........how did you know to do that?
Funrover is online now   Reply With Quote
Old 10-15-2005, 08:20 PM   #8 (permalink)
frickjp's Avatar
LR brake switches are slightly less than, shall we say, reliable. We get this phone call on occasion. It's a simple solution that most folks can accomplish. Everyone has a quarter. It beats some grease covered tow truck monkey dragging it up on the rollback with the truck in park.
