Old 05-09-2006, 02:42 PM   #1 (permalink)
Majesticdisco1
disco12's Avatar
Default I think my gearbox is leaking drops
I looked under my D1 where the gearbox is and noticed that around the nuts of the gearbox there is something coming out very very little but it leaves a few drops on my driveway I can shift for high to low no problem just want to know what is causing this. Is it something i need to thighten or something. I don't want to screw it up. can someone help me please
THANKS
1996 D1
RTE 3"
33" BFG MUDS
Old 05-09-2006, 02:55 PM   #2 (permalink)
You have been around Rovers to know that they will leak to keep up the olf UK image.
Your t/case is leaking, it is normal at some point and not a big deal.
You need to change your fluid if it hasn't been done in the last 20,000 miles and check it once a week or two and see what volumn you are actually loosing. May find you need to add every 3 or 4 months and if the drip marks don't bother your, you're OK if it is a bother plan on pulling the case and have all the seals replaced, cause they all will leak at some time.
Old 05-09-2006, 02:59 PM   #3 (permalink)
Majesticdisco1
disco12's Avatar
Thanks Mike Ur a Big help.
1996 D1
RTE 3"
33" BFG MUDS
Old 05-10-2006, 01:37 AM   #4 (permalink)
The Best 4X4XFar
300bhp/ton's Avatar
Hay don't worry about it, they're supposed to leak - it's an anti-corrsive measure
Nah, seriously don't worry about it I don't think I've ever seen a Land Rover that didn't drop a bit of oil from somewhere, it's all part of the course.
The Best 4X4XFar
Old 05-10-2006, 07:24 PM   #5 (permalink)
I would rather die on my feet then live on my knees.
Discodude19's Avatar
Mine is doing the same thing i just keep convincing myself that i ran through a puddle or something.
Discodude19 is offline   Reply With Quote
Old 05-15-2006, 12:35 PM   #6 (permalink)
on, off, on, off, on...
Capt. Ron's Avatar
Went to a British car show in N. Georgia this past weekend. Looked in the engine bays of some pristine MG's. Guess what, they were leaking too! My t-case leaks too. Just a few drops that dangle off the bolts.
03 Disco w/CDL
95 Disco
98 Disco: my first (gone)
Capt. Ron is offline   Reply With Quote
