#62 (permalink) |
OK, so its done.... Supercharger is now fitted and ready to go. Its too late (& dark) now so fist call in the morning then its over to the mad mile for a test flight
wish it luck ![]() Yes I know it needs a wash under the hood :0 |
#63 (permalink) |
Well well well, they do infact work really good. First off I did approx 50kms with it turned off and like wow, the thing is heaps faster from take off and pulls really great. Idle raised (on its own) by 100rpm "from" 750rpm "to" 850rpm.
Now all of the above has to be down to the K&N supa large filter thats clamped to it Then came the main test "Mad Mile"I floored it from standing start and then hit the switch..... Took 7.5 seconds to hit 100kms (approx 62mph) and then pulled straight to 130kms very quickly then this huge logging truck decides to pull out on me!!!!! so that was the first real test all over.... I had my right foot planted hard down the whole time Part two, well I drove with the supercharger on and off all day and its great. The second testing was done with one of our trailers hitched up so add approx 800kgs and it pulls up the hills ammmmmmazzzzzzing to say the least. To be perfectly honest you do NOT have a power-surge when hitting the switch, more like a mmmmmmMMMMMM so no big thrill seekers need apply LMAO but hey, its a significant change from the stock air cleaner for sure. Would recommend 100%. Dont forget the static turbine is also installed too ![]() |
#64 (permalink) | |||
hurray for books!
Btw, the 8202 is on sale right now at Summit. Just FYI. ![]()
"It's all good, it'll clear, it'll clear *CRUNCH* "![]() Ivan -1994 Discovery Lounge and Midwest mod Quote:
#65 (permalink) | |
The Urban Motorist
![]() Join Date: Sep 2004
Adam in NYC
-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=--=-==-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-= Owner of a 1996 Land Rover Discovery 1 in Beluga Black or the Dirt of the Day. Where we are going,we don't need roads. Nothing in education is so astonishing as the amount of ignorance it accumulates in the form of inert facts. ‘The Education of Henry Adams’ (1907) ch. 25 |
#66 (permalink) |
Hi Adam, its going great, no more mods required at all
Like I said its no BIG surge of power but it certainly does make a huge diff to the take off power but maybe thats the massive K&N thats added to the super. I recon its worth the $100usd for sure... |
#67 (permalink) | |
#68 (permalink) | ||
The Urban Motorist
Before we become accustomed to stating which ignition module works best for in this case, the Land Rover, maybe we should double check the installation and make sure all proper electrical connections are done and done well. Most factory HEI systems are fed very well from the battery and alternator system. If you don't clean up after pulling out the factory ignition system and just drop in an aftermarket ignition system, do you think something like a Jacobs or any other HEI system would work properly. Probably not. Ignition systems need a premium electric connection for itself and the ignition coils. The written instructions and the ignition kits themselves are ,at best, a compromise. They are trying to aim for a broad base: those who want to upgrade their cars at home (auto home hobbyists) and those who want a higher spec ignition system for track use(amateur and semi-pro track racing) . If the manufacturer gives out too much information, most customers will drown with the extra information. The ignition manufactuers make a blind and calculated guess and choose to write for the widest audience they can and they hope that those instructions work for whoever does the installations. If you, as a non-track auto owner, wish to install an ignition system, you take a risk and you gotta take some responsibilty for the install. If you have no prior expierence, it is really hard to state just because you drop it , it don't work, it gotta be "their" fault. How would they know, they don't know where their product is going to end up. Quote:
Adam in NYC
#69 (permalink) | |
I have the MSD 8.5's but pretty much gave up being able to do anything with the coil pack. |
