Old 08-26-2007, 12:10 AM   #1 (permalink)
Default injector advice?
i think ive narrowed my problem down to leaky injector(s).
does anyone have any input on what injectors to get? i stumbled across this place using ford racing injectors http://www.fiveomotorsport.com/Injector_SetsENGLAND.asp at $330 a set.
Ramathorn is offline   Reply With Quote
Old 08-26-2007, 03:41 AM   #2 (permalink)
Ian Matthews
p76rangie's Avatar
It would help if you mentioned what motor you had and what brand/type of injection system is on it.
p76rangie is online now   Reply With Quote
Old 08-26-2007, 05:09 AM   #3 (permalink)
I took apart a DI a short while ago that had pink injectors from 50 Motorsports in the 3.9L. The owner couldn't say enough good things about them. I know of another person over on discoweb.org (fnnuts) with a 4.6L that has a set from 50 Motorsports as well although I am not certain of the model injector he's using. Bottom line, they seem to work well in Rover motors. If injectors are what you really need, giive them a call with the details on your motor and I'm sure they can recommend a suitable replacement that will save you tons of money.
Paul Grant
paulgrant@mac.com
http://stores.ebay.com/Classic-Rovers
203-770-1699
Old 08-26-2007, 07:38 AM   #4 (permalink)
sorry theses are for my 95 3.9L.
im going to try some other things today to see if the injectors are my issure but it really sounds like the same problem that others are having/ have had with their disco's.
Old 08-28-2007, 08:01 AM   #5 (permalink)
on, off, on, off, on...
Capt. Ron's Avatar
You mean the fuel pump?
03 Disco w/CDL
95 Disco
98 Disco: my first (gone)
Capt. Ron is offline   Reply With Quote
Old 08-28-2007, 08:33 AM   #6 (permalink)
what about the fuel pump?
Old 08-28-2007, 08:48 AM   #7 (permalink)
sven's Avatar
You can buy NEW ford motorsport injectors from summitracing.com for around $200. They are the exact same ones 5-O is selling for a lot less.
99 D1
73 Series SWB
95 RRC LWB - Sold
Old 08-28-2007, 09:44 AM   #8 (permalink)
Capt. Ron's Avatar
I was recalling some other posts about similar problems where the fuel pump was mentioned; unless you know for sure it's the injectors.
03 Disco w/CDL
95 Disco
