Links
Old 05-04-2008, 07:36 PM   #1 (permalink)
Default injectors not pulsing 95 3.9 auto
does anyone know what would cause the injectors not to fire?what triggers the injectors to pulse? I have tried another ecu and still no injector pulse. the 95 has a distributor, no cam sensor, no crank sensor. is there a relay for the injectors? does the ecu get a signal from the ignition system like the old bocsh systems did with the tach input. i am baffled
bobm7007 is offline   Reply With Quote
Old 05-05-2008, 07:05 AM   #2 (permalink)
Elemental's Avatar
The computer needs to see at least 50 rpm on the tach signal(off the coil) before it turns on the injectors.
RRC in need of Help, elemental disco mike various other smart people ArmyRover Range Rover Classic 99 05-14-2008 03:32 PM
Land Rover LRX unveiled, courtesy of Auto Motor und Sport Administrator Land Rover News 7 12-19-2007 12:48 AM
Injectors... advise. texasrover Discovery Series I 7 01-17-2006 06:42 PM
RRC Parts (cheap) Injectors, Cylinder Head, etc... yieldsign2 Land Rover Parts and Accessories 0 01-09-2006 09:02 AM
Injectors... texasrover Discovery Series I 5 07-20-2005 06:56 AM
