Old 09-23-2006, 12:05 PM   #1 (permalink)
JesusIsLord
9dawgs's Avatar
Gallery: 2
Default Intermittent starting problem - revisited...
Ok guys, I've replaced the fuel filter, with negres. I just replaced the multi-unit fuel pump relay. Still no joy... It seems like it just doesn't get fuel for a few starting attempts then all of a sudden it starts right up like nothing happened. I'd like to exhaust all "simple" possibilities before I replace the fuel pump. Anyone have any other thoughts on this?
This I know:
The fuel pressure is not bleeding off because the longer the vehicle sits the better chances of it starting right up. (ie; I take it to work and it starts everytime I get in to go home after sitting for 8hrs) If I stop to get gas on the way to work, then it won't start on first attempt when I try to leave the gas station. It takes about 3 tries to get it started.
If I feather the gas pedal I can start it on the first attempt but when I let my foot off the pedal it just dies. I can drive it this way but I have to keep the RPMs up to keep it from stalling.
It has to be some electrical component that fails intermittanly when it gets hot. Any help from a certified Rover mech would be greatly appreciated.
9dawgs
'99 Discovery I
'99 Chevy Astro 4X2 w/4" Lift (family truckster)
17' Basstracker w/40HP Mercury
11' Jon Boat w/numerous antique outboards
9dawgs is offline   Reply With Quote
Old 09-24-2006, 01:23 PM   #2 (permalink)
Georgecore's Avatar
have you checked the main and/or fuel pump relays? I remember owning a honda that had the same symptoms your describing and it ended up being a relay.
Georgecore is offline   Reply With Quote
Old 09-25-2006, 06:25 AM   #3 (permalink)
MG
me.guevara's Avatar
Default iacv?
No certification here (not even any formal training in wrench-turning), so take it fwiw: the feathering that you have to do to the gas pedal sounds like a similar issue I had with the stepper motor (idle air control valve - iacv) on the side of the plenum chamber. When it goes, you'll have a bunch of stalling issues - I've become really good at keeping the engine running with my toes and braking with my heel, simultaneously.
Clean your iacv and make sure it has a good seal to the plenum. If you have access to another Disco, swap the actuators to see which vehicle keeps the problem. Looking at your sig, I notice you have a Chevy Astro - I'm pretty sure that the iacv on the Astro is interchangeable with that of the Disco (at least for a '95 Disco it is, but I'm not sure about what model year Astro - see http://www.rangerovers.net/discoparts/).
Good luck!
Are you running rich, too? That's another symptom.
________________________
MG
'95 Disco I, 3.9L V8i 5-speed
Discoverying Bolivia...
Old 11-07-2006, 05:53 PM   #4 (permalink)
my name is mark and i have a 99 that randomly stalls and starts but no fire when hot . the intermittent part i have come to believe is a sensor ie: coolant sending unit,fuel temp sensor , or crank sensor my understanding is when one of these gets old and hot they cause no start symptoms
mark555 is offline   Reply With Quote
Old 11-07-2006, 07:53 PM   #5 (permalink)
Super Moderator
Disco's Avatar
I'd suspect the Coolant Temperature Sensor.
Old 11-15-2006, 04:32 PM   #6 (permalink)
wrench-turner
AndeanDiscovery97's Avatar
I'm no certified Rover Tech, but had same issue. Changed potentiometer-butterfly and problem was solved.
AndeanDiscovery97 is offline   Reply With Quote
