JesusIsLord
Ok guys, I've replaced the fuel filter, with negres. I just replaced the multi-unit fuel pump relay. Still no joy... It seems like it just doesn't get fuel for a few starting attempts then all of a sudden it starts right up like nothing happened. I'd like to exhaust all "simple" possibilities before I replace the fuel pump. Anyone have any other thoughts on this?
This I know: The fuel pressure is not bleeding off because the longer the vehicle sits the better chances of it starting right up. (ie; I take it to work and it starts everytime I get in to go home after sitting for 8hrs) If I stop to get gas on the way to work, then it won't start on first attempt when I try to leave the gas station. It takes about 3 tries to get it started. If I feather the gas pedal I can start it on the first attempt but when I let my foot off the pedal it just dies. I can drive it this way but I have to keep the RPMs up to keep it from stalling. It has to be some electrical component that fails intermittanly when it gets hot. Any help from a certified Rover mech would be greatly appreciated.
9dawgs ![]() '99 Discovery I '99 Chevy Astro 4X2 w/4" Lift (family truckster) 17' Basstracker w/40HP Mercury 11' Jon Boat w/numerous antique outboards |
#3 (permalink) | |
MG
![]() Join Date: Aug 2005
Clean your iacv and make sure it has a good seal to the plenum. If you have access to another Disco, swap the actuators to see which vehicle keeps the problem. Looking at your sig, I notice you have a Chevy Astro - I'm pretty sure that the iacv on the Astro is interchangeable with that of the Disco (at least for a '95 Disco it is, but I'm not sure about what model year Astro - see http://www.rangerovers.net/discoparts/). Good luck! Are you running rich, too? That's another symptom.
________________________ MG '95 Disco I, 3.9L V8i 5-speed Discoverying Bolivia... |
my name is mark and i have a 99 that randomly stalls and starts but no fire when hot . the intermittent part i have come to believe is a sensor ie: coolant sending unit,fuel temp sensor , or crank sensor my understanding is when one of these gets old and hot they cause no start symptoms
