Old 09-09-2008, 10:57 PM   #1 (permalink)
jake_ak_cent's Avatar
Gallery: 2
Default its to low help
ok so i found a site with 2" spacers for a coil conversion kit and it brought up a question.
would these spacers work on if the truck came stock with the coil suspension or only for the conversion kit?
heres the link LAND ROVER Air Suspension Parts - Range Rover 1995-2002 (4.0 and 4.6) P38A
____ROVER____
(Roll Over Very Extreme Rocks)
______
JAKELRD1 96' D1 "TK"
jake_ak_cent is offline   Reply With Quote
Old 09-10-2008, 01:48 AM   #2 (permalink)
Dutchgit's Avatar
It wouldn't work if the shock is inside the coil (on the front) as the shock mounts directly to the axle and looking at that raising kit there's no hole in the center for the shock. You might need/want longer shocks as well.
Nothing is sure but death and taxes.
Dutchgit is offline   Reply With Quote
Old 09-10-2008, 08:11 AM   #3 (permalink)
So what exactly are you wanting to do, if it is to raise your truck, if you have the original factory suspension, they are not a good idea. They work well with a replacement suspension like RTE or OME but with your old tired suspension you will just feel even more top heavy especially off the road.
Old 09-10-2008, 11:10 AM   #4 (permalink)
Gallery: 2
i want to raise my truck and wanted to know if the spacers would fit on a factory suspension. but sounds like they wont so im just going to get better springs and spacers
check these out
Rovers North.com - Land Rover Series, Defender, Discovery and Range Rover Parts - COIL SPRING SET - GENUINE DISCOVERY HEAVY DUTY
Rovers North.com - Land Rover Series, Defender, Discovery and Range Rover Parts - 2IN LIFT SPACER FOR COIL SPRING SUSPENSION (SET OF 4)
tell me what you think. and am im going to need shocks with that? if so im going with ome shocks
____ROVER____
______
Old 09-10-2008, 11:50 AM   #5 (permalink)
Thor's Avatar
I think Rover Tym has spacers that allow through shocks in the coil, in fact I think you can mount the shock to the spacer for extra length.
Look at the spacers on their site.
Todd
Carpe Rangius Roverum
