Links
Old 04-30-2008, 03:08 PM   #1 (permalink)
discowilson's Avatar
Default just replaced brake pads....
so i replaced my worn down brake pads, and i out everythin together i still have that crunching and metal to metal sound that i had before when my pads were bald.. is this an expensive fix or an easy fix?
ahhhhhhhh
1996 D1 SE7
discowilson is offline   Reply With Quote
Old 05-01-2008, 01:25 PM   #2 (permalink)
antichrist's Avatar
Did you install the all the right way round?
Tom Rowe
Atlanta, GA
62 88 reg
67 NADA x2
95 D1
95 D90
Old 05-01-2008, 02:40 PM   #3 (permalink)
what do you mean install the right way? i thought they went in the same way they came out? on one of the brake pads there was a little im gonna guess sensor but there was no place to hook that up? was i supposed to use that? idk im guessing new rotors? or my rotors need to be cut?
1996 D1 SE7
Old 05-01-2008, 02:53 PM   #4 (permalink)
Elemental's Avatar
What did you do to break in your pads?
Old 05-01-2008, 03:56 PM   #5 (permalink)
actually im a tard i let someone else do the brakes in my driveway and i wasnt supervising and bam! they put the pad in backwards,ugh, fuck, well its fixed now but now my rotor is all cut up but im just gonna drive it for now cause i dont have monies to buy rotors hah, oh well thanks for the help.
1996 D1 SE7
Old 05-01-2008, 06:18 PM   #6 (permalink)
antichrist's Avatar
That's what I meant. Not that uncommon, believe it or not.
Tom Rowe
Atlanta, GA
62 88 reg
67 NADA x2
95 D1
95 D90
Brake pads Neo1975 Discovery Series II 7 04-19-2008 06:34 PM
Brake Pads and Rotors replaced / ABS / TC failure beej414 Range Rover P38, Mk III and Range Rover Sport 0 06-22-2007 03:09 PM
wheel cylinder rebuilding theclay Series Land Rovers 23 05-21-2007 04:45 PM
Brake pads me.guevara Discovery Series I 13 05-01-2006 11:48 AM
Brake Rotors and Pads How-To werldcup Discovery Series II 4 03-23-2006 07:16 PM
