Links
Old 05-07-2008, 09:34 PM   #1 (permalink)
Disco 1's Avatar
Default Key Wont Turn
Ok so apparently my rover won’t crank, actually the key won’t even turn. I actually went on a trip and took my mom’s Subaru so I’m not with the truck but my parents are frustrated and I want to get an opinion on what yall think the issue is and anything I could try before they go paying someone to do something. So basically as I understand it, when they went out to crank it one evening it acted like the key wouldn’t turn and the steering wheel was locked up. I don’t know how to describe this exactly but it’s happened to a few vehicles I’ve driven, and people have told me it’s happened to them before. Usually they finally get it to work by turning the steering wheel back and forth and fighting with it for a while until the key turns. At first this is what my parents thought it was but they fought with it and tried for a few hours by now probably as I understand it and it won’t turn. They’ve decided that this is not one of those normal occasional times, but rather that something’s broken. They’ve talked to a locksmith and the dealership and they suggest that the ignition is bad and needs replacing. If this is the case then that’s that, but I want to be as sure as possible that it needs to be replaced before I go spending this money. What do yall think? Any suggestions? They’ve fiddled with the key and steering wheel in every way possible. What else?
Thanks, Dane
1998 D1
Disco 1 is offline   Reply With Quote
Old 05-08-2008, 02:27 AM   #2 (permalink)
I have a similar problem, although not quite as severe, where I can turn the truck off but the key won't turn the last notch letting me pull it out completely.
I've found out this only happens when I park on the uneven gravel section of the driveway, on a slight slope and with the tires at different heights because of the bumps. the truck goes into park but it's like it doesn't go all the way and holds on to the key as if it was still on. Usually releasing the brake pedal and letting the truck settle completely and shifting a bit from Neutral to Park helps it "settle" and the key comes right out.
Dunno if this is what's afflicting your Disco but beware the dealer saying your ________ is broken, it'll cost you more than your truck probably did to fix
Ben Rover is offline   Reply With Quote
Old 05-08-2008, 05:22 PM   #3 (permalink)
same thing happened to me and many others. The ignition switches are junk and after reviewing the previous records, my disco is on it's third ignition. I pulled mine out and removed most of the tumblers ( so it would work with my door key) and removed the steering lock and the annoying push in feature. Works like a charm now and there is nothing inside except the three tumblers to ever worry about.
amschnellsten is offline   Reply With Quote
Old 05-10-2008, 05:21 AM   #4 (permalink)
Common problem, been happening on mikne and off for 3 years. For a quick fix try tapping the end of the lock with a small hammer being carefull not to hit the plastic light ring. This usually frees mine up
Roverdisco98 is offline   Reply With Quote
Turn Signal Problem nate13 Discovery Series I 8 04-27-2008 06:43 AM
Won't turn over if CABIN is freezing Black Magic Discovery Series II 6 02-07-2008 05:49 PM
Key - difficult to turn in ignition (starting and turning off) mm_putnam@yahoo.com Range Rover Classic 3 11-10-2007 05:21 AM
P38 ..Non-Starter!! Fozzy Range Rover P38, Mk III and Range Rover Sport 25 04-12-2006 03:50 AM
99 4.6 is superlocked and won't reset Spring Range Rover P38, Mk III and Range Rover Sport 9 12-05-2005 04:46 PM
