Key won't turn in ignition... suggestions? - Land Rover Forums : Land Rover and Range Rover Forum
» Auto Insurance
» Featured Product
Wheel & Tire Center
Old 09-29-2011, 07:09 AM   #1 (permalink)
Default Key won't turn in ignition... suggestions?
Howdy -
key wont turn when placed into the ignition. battery is fine. steering wheel is *not* locked. car is definitely in park. i tried turning key multiple times while moving the steering wheel side to side, etc. took to local LR dealer. over a thousand bucks to replace the ignition assembly.
Is there a better (read: significantly cheaper) option? Any ideas you might have would be most appreciated. Just bought this thing a month ago for about 2K - hard to imagine putting 50% of that into it for a key tumbler...
tyrrhena is offline   Reply With Quote Quick reply to this message
Old 09-29-2011, 07:35 AM   #2 (permalink)
The ignition switch assembly is something you could do on your own. Also, I can get you a brand new Land Rover ignition switch for a fraction of what the dealer would charge you.
If you want to go that route, let me know. I can certainly give you step by step instructions regarding the removal and installation of the switch. It shouldn't take a first timer much more than a couple of hours to do. Total cost, under $200.
Paul Grant is offline   Reply With Quote Quick reply to this message
Old 09-29-2011, 09:25 AM   #3 (permalink)
Although possibly not as good a solution as the above, here is another approach and it's free...
ignition lock fix - Land Rover Forums - Land Rover Enthusiast Forum
Ed Z is offline   Reply With Quote Quick reply to this message
Old 09-30-2011, 02:18 PM   #4 (permalink)
Paul - still debating a course of action. I appreciate the quick reply. Will this solve the entirety of the problem?
Old 09-30-2011, 02:20 PM   #5 (permalink)
I can't see how a brand new ignition switch won't solve the problem. Everything will be like it was when the truck was new.
Old 09-30-2011, 02:32 PM   #6 (permalink)
HI PAUL - my apologies. I am neither good with cars, nor knowledgeable about LRs. Just making sure I understand properly before I make a decision...
Old 09-30-2011, 02:34 PM   #7 (permalink)
No problem at all. Like I said, if you decide to go this route, I'll help you with directions. I've removed well over 100 of these over the years. Once you get over the notion of what you're doing and focus on the steps, it's really not hard at all.
Old 10-04-2011, 05:08 PM   #8 (permalink)
Paul - interested in moving forward with this here... let me know how to go about reaching you, payment, etc...
Old 10-05-2011, 06:31 AM   #9 (permalink)
I have to see if I can still get the switches. I will get back in touch with you later today.
Old 10-06-2011, 10:27 AM   #10 (permalink)
I sent you a PM. I'm ready when you are.
Thanks,
Paul
Old 10-06-2011, 01:47 PM   #11 (permalink)
Switch or lock assembly?
PTSchram is offline   Reply With Quote Quick reply to this message
Old 10-06-2011, 01:51 PM   #12 (permalink)
It's a complete ignition switch assembly. Not just the ignition switch. It's everything right down to two new keys. Even the shear bolts are new.
Old 10-06-2011, 03:05 PM   #13 (permalink)
Like this one:
Ignition Switch Lock | Land Rover Electrical Parts, Batteries, Relays, Lamps & More
Old 10-18-2011, 12:02 PM   #14 (permalink)
Hey Paul - got the part last night. Talk to the Svc Mgr at the local LR dealer - claims that the one you sent me was for a "manual transmission" Discovery - and that if it gets put in, it will not allow me to shift. That accurate in your experience? He said the part # that I need is STC1436, and the part # that you sent me is STC1435. Need your expertise here... Thanks.
Old 10-18-2011, 12:13 PM   #15 (permalink)
I put a call into my supplier and am waiting for a call back. I will be in touch as soon as I hear from him.
Quick Reply
Message:
Options
Register Now
If you do not want to register, fill this field only and the name will be used as user name for your post.
Password
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
Alarm armed or bad ignition? key wont turn bikeG976 Discovery Series II 1 12-19-2010 10:49 AM
Ignition key opens the doors and hatch but will not turn in the ignition. sanmigmike Range Rover Classic 3 08-26-2010 07:11 PM
Disco No Go! Ignition Key Will Not Turn! Beirut_Rover Discovery Series I 10 04-17-2008 02:27 PM
Key - difficult to turn in ignition (starting and turning off) mm_putnam@yahoo.com Range Rover Classic 3 11-10-2007 05:21 AM
Ignition Key won't turn galloj Discovery Series II 1 12-03-2005 01:15 PM
Powered by vBulletin® Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.3.2
All content is copyright 2004-2008 www.landroversonly.com and its original authors. Land Rovers Only is in no way affiliated with Land Rover
